BlueNRG - Non-connectable Advertising
matej
Posted on September 17, 2014 at 13:24
I'm wondering if there is some possibility that BlueNRG (which has established connection - slave role) will produce non-connectable advertising (same as device C at Bluetooth 4.0 core spec. Vol1, Part A, 4.1.2)?
After sending ''LE Read Supported States'' command, I get result (0x00000000130000FF) which tells us (according to Bluetooth 4.0 core spec. Vol2, Part E, 7.8.27 ) that Non-connectable Advertising State and Slave Role combination is not supported
Thanks for any advice.
BR
Matej
#advertising #bluenrg
Posted on November 17, 2014 at 16:20
Hi Matej,
as you say, the BlueNRG cannot support the state: ''Non-connectable Advertising State and Slave Role combination''.
Graziella
