BlueNRG-MS (X-NUCLEO-IDB05A1) too much power consumption
giver3
Posted on March 16, 2016 at 09:38
Hello everyone.
Software:
X-CUBE-BLE1 (v. 2.5.2)
http://www2.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/x-cube-ble1.html
Example: Sensor Demo Application with DMA and low power mode (Project Name: DMA_LP_SDemo)
1) Equipment: NUCLEO-L053R8 + X-NUCLEO-IDB04A1
- Current consumption in operation mode advertising: about 15 �A
- Current consumption in operation mode connections: about 130 �A
2) Equipment: NUCLEO-L053R8 + X-NUCLEO-IDB05A1
- Current consumption in operation mode advertising: about 300 �A !!!
Power supply voltage 3.3 V.
The problem lies in the very high consumption of X-NUCLEO-IDB05A1 mode advertising.
Has anyone encountered this problem?
#bluenrg-ms-x-nucleo-idb05a1
Andrea Palmieri
Posted on March 17, 2016 at 12:40
Dear Customer,
The difference in current consumption observed in Advertising mode is due to different default values for Minimum and Maximum Advertising Intervals used by X-NUCLEO-IDB04A1 and X-NUCLEO-IDB05A1 firmware, respectively. You can tune such values when calling the API: “aci_gap_set_discoverable()�.
Kind regards
Andrea
Hello everyone.
Software:
- Current consumption in operation mode advertising: about 15 µA
- Current consumption in operation mode connections: about 130 µA
- Current consumption in operation mode advertising: about 300 µA !!!
giver3
Posted on March 18, 2016 at 14:09
Thank you for the quick reply.
I set the min and max advertising time.
It was just what I needed.
Now Current consumption is about 2 µA
This is the
appropriate value
I greet and thank you
for your help.
