SPC560D - power control modes
ssk
Posted on June 30, 2015 at 16:50
I am using standby mode for SPC560D MCU. The datasheet mentions about using DRUN or software reset for exiting this mode. Can you please explain on,
1. How to configure the DRUN mode? I tried using API 'halSPCSetRunMode' for switching between modes. But when used for DRUN mode, it does not exit the standby mode correctly and a power reset is required. Is any thing missing for this?
2. Which are the ways to use software reset for SPC560D? Can I use watchdog reset as a software reset? Is there any other means for software reset?
Thanks in advance for any help.
Mike.
61 REPLIES 61
Posted on December 11, 2015 at 10:17
Hi Erwan,
After some days pause, I found a solution for this reset issue. It seem s like that the CheckStop Reset is linked to the RESET Pin. And nobody will believe it, there is register for it. If the Register
RGM.
FBRE
B
BE_CHKSTOP
is set to 1 I have the same behavior with the debugger and without the debugger. Therefore all reset flags will be set correctly.
Thank you for your support.
kind regards
Philipp
Erwan YVIN
Posted on December 11, 2015 at 10:30
Hello Philipp ,
very good finding ;)
  Best regards
                Erwan
