2021-07-07 6:19 AM
In our project, we have selected SPC584B70 as the MCU. Could you please provide help to support model based design and code generation using MATLAB/Simulink for SPC584B70 MCU ?
I can see that SPC58 series is supported by Embedded Coder from MathWorks for code generation. I would like to know the code generation settings that I need in MATLAB Embedded Coder to make to generate optimized production code for SPC584B70.
I am using SPC5 Studio IDE having built-in free GCC compiler for the code compilation.
Thank you in advance.
Best regards,
Sreejith
2021-07-12 2:29 AM
Hello ,
we do not support Mathworks integration in SPC5Studio.
Anyway, SPC5Studio IDE is an eclipse based environment.
It is possible to install some Eclipse features in SPC5Studio IDE.
i recommend you to follow the tutorial
How to Integrate Eclipse into the Real Time Workshop build environment (Cf link below)
For any installation issues please contact Mathworks.
Best regards
Erwan
2021-07-12 2:29 AM
Hello ,
Best regards
Erwan
