how to configure flex pwm to give complementary pwm of 20 khz.
kjay
.i need help with calculating clock and time peroid and waht is other pwm pin if pwm0 has d10 which is complemetary pin in spc56el70l5-disp
82 REPLIES 82
kjay
thanks for your help...i have one issue...my spc5660l5 is normally 40deg cel while it drive motor or CAN communication..is it normal..or am i drwing current from pwm pins...but spc5670 discovery though stays cool...as compared..is there an issue..
kjay
i need to know SPC56EL60L5 has EEPROM memeory...i have this driver component given in the example of SPC56EL70L5 but i change the platform..it shows error this device not supported by EED driver.whats is the isssue..please help.
zambrano.luigi
Hi
currently the EEPROM Emulation Driver is provided only for the SPC56EL70L5 and not for the SPC56EL60L5.
Best Regards,
Luigi
