2020-01-09 3:40 AM
We are writing 2kbytes of Data into the dataflash at the rate of 8bytes/1ms before ECU enter into sleep state.
When we do this activity several times, DATA Flash got corrupted and ECU stops working.
We had followed document en.DM00068954 , for our implementation.
Could you please help us resolve this issue on priority?
2020-01-14 8:03 AM
Hello ,
could you try this application
SPC560Bxx_RLA Flash Test Application for Discovery ?
In case of Crash , the best thing is to check to PC,R14 with your debugger
Best regards
Erwan
2020-01-14 8:03 AM
Hello ,
Best regards
Erwan
