2018-06-28 2:20 AM
I'd like to cross-compile code without using SPC5Studio for
SPC570S5E1 on a linux box, which version of gcc would I need and what flags should I use? Do I need a special toolchain for the e200z0 core?
Thanks in advance
#gcc #cross-compilationSolved! Go to Solution.
2022-09-23 2:21 AM
Hello ,
You can find the linux freegcc here :
http://spc5tools.spc5studio.com/tools/freegcc/plugins/
Best Regards
Erwan
2018-06-28 7:44 AM
Hello Yalin ,
you can find the freegcc for powerpc vle (linux) in the following directory (cf plugins)
http://spc5.drive.cloudforge.com/projects/spc5tools/updates/
Compilation is OK
for your information we have a SPC5Studio Linux beta version
Best regards
Erwan
2022-09-23 2:04 AM
I have the same problems in order to cross-compile in Linux base environment the SPC570S5E1 with command line, but the suggest source is not longer available.
Can i find the fregcc?
Thanks.
Best regards,
Gianni
2022-09-23 2:21 AM
Hello ,
Best Regards
Erwan
2022-09-23 5:37 AM
Thank you Erwan.
Also, is there any st document designed to support command line development in unix environment?
Best regards.
Gianni
2023-04-04 3:51 PM
Hi, I'm looking for some tool for compile SPC58 on a linux box, no mother if GUI or CLI or java based commands. Something to get out of windows Have you some tool for that. Thanks.
