STM32cubeide
Hi friends,
I am built one custom made PCB with by using STM32F103C8T6 IC for my project purpose.But ,When i am trying to upload my source code by using stm32Cubeide it shows below error.
Error in final launch sequence:
Failed to execute MI command:
target remote localhost:61234
Error message from debugger back end:
localhost:61234: Connection timed out.
I didn't know how to solve this error .I am tried to solve this error but did not solve the error till now  .so i need your help to solve this error can any one help me to solve my problem?
The usual suspects:
  • Check VCC voltage. Note that programmers typically do not supply power.
  • Check part orientation. Pin 1 is on the lower left when "STM32" reads from left to right.
  • Can you connect in STM32CubeProgrammer? Does it display a voltage?
  • Do you have an official ST programmer or a counterfeit one? STM32CubeIDE does not play well with knock-off programmers.
Andrew Neil
@Vignesh_V  If you're not sure, see:
https://community.st.com/t5/stm32-mcus/how-to-recognize-a-genuine-st-link-v2-versus-a-cloned-one/ta-p/49471
See also:
https://community.st.com/t5/stm32-mcus/how-to-solve-debugger-connection-issues/ta-p/49693
Rim LANDOLSI
Hello @Vignesh_V ,
Could you please check these points:
  • Ensure that the ST-LINK or other debugging interface is properly connected to the STM32F103C8T6 board
  • Verify that the power supply to the board is stable and sufficient.
  • Update ST-LINK Firmware
  • In the debug configuration, Verify that the correct port localhost:61234 and you can change it to 61238
Thanks,
Rim.
