jean_bonneau
Could not verify ST device when attempting to debug
SOMETIMES (not always), when i try to debug (and only when i try to debug, run does its job well) with STM32CubeIDE my Riverdi board, i encounter the "Could not verify ST device! Please verify that the last version of the GDB-server is used for the connection" error. It happens right after
Loading RTOS driver... ThreadX
Connecting to GDB server 127.0.0.1 on port 61234 ... Connected
Listen for GDB connection on port: 60000 ... Connected
.if this helps.
Downloading code with run is always fine, and sometimes the debug option works, but not always. It is really annoying to rely on luck to make the *** thing work. I tried unplug-replug. The board is definitly not counterfeited, same goes for the ST-Link.
mƎALLEm
What STLINK device are you using? a genuine ST link? it could be a counterfeit ..
See How to recognize a genuine ST-LINK/V2 versus a cloned one
jean_bonneau
It looks like a geniune ST-Link/V2
mƎALLEm
Could you please share real pictures of your ST-LINK?
Andrew Neil
