Bea_12
Main.h is not found
  • January 27, 2025
  • 4 replies
  • 7671 views
I generated the code in CubeMX and opened it in VSCode. However, I cannot run the code because VSCode cannot find main.h. I'm not sure why this is happening. I've generated the code twice, but the problem persists. The main.h file is located in the Core > Inc folder, and main.c is in the Core > Src folder. Does anyone know what might be causing this issue? Thanks!
KnarfB
Did you import the project and open the folder? Here are instructions:
How to use VS Code with STM32 microcontrollers - STMicroelectronics Community
hth
KnarfB
Bea_12
Bea_12Author
Yes, I followed the instructions, but I have the feeling that something might be off with the settings or something else. Is there something I might need to adjust?
Andrew Neil
Andrew NeilBest answer
Karl Yamashita
Principal
January 28, 2025
upload your ioc file
Bea_12
Bea_12Author
It seems like I've resolved one of the issues by changing some settings in STM32CubeMX. However, the main.c and main.h files are still incorrect. No matter what I change, the files remain problematic. Additionally, I forgot to install STM32CubeCLT, but that hasn’t affected anything else so far. I do not know what i could change that my program works. Does anyone know please explain it to me.
Andrew Neil
Excellent - what settings did you change?
Please 'Mark as solution' the post which resolved the issue:
https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256
That's a new question - please start a new thread for that, then post a link here to that new thread.
In your new thread, you'll need to give more details for people to be able to help you - see: How to write your question to maximize your chances to find a solution
Andrew Neil
