Olivier GALLIEN
Olivier GALLIENBest answer
Nov 24, 2020 07:53 UTC
Hi @MVENN.1​ ,
Only the last version 2.6 is supported on Ubuntu 20.04.
And since this version the JRE is bundle inside STM32CubeProgrammer and no longer need extra JRE package.
Olivier
MVENN.1
MVENN.1Author
Nov 24, 2020 13:42 UTC
When i flash the image in between connection is loss
Olivier GALLIEN
Nov 24, 2020 13:47 UTC
Hi @MVENN.1​
Please follow carefully the Getting Started
Just pay attention that when reconnecting during download the USB device is well catch by your Virtual Machine and not your host
Olivier
MVENN.1
MVENN.1Author
Nov 24, 2020 13:48 UTC
look at this once please provide suggestion.
12:03:28 : STM32CubeProgrammer API v2.6.0
12:03:35 : USB speed : High Speed (480MBit/s)
12:03:35 : Manuf. ID : STMicroelectronics
12:03:35 : Product ID : DFU in HS Mode @Device ID /0x500, @Revision ID /0x0000
12:03:35 : SN : 0046003E3338510634383330
12:03:35 : FW version : 0x0110
12:03:35 : Device ID : 0x0500
12:03:41 : Read TSV File: D:\Projects\Tag\stm32MP1\stm32mp1-openstlinux\images\stm32mp1\flashlayout_st-image-weston\FlashLayout_sdcard_stm32mp157c-dk2-trusted.tsv
12:03:41 : Number of partitions: 9
12:03:59 : Start Embedded Flashing service
12:03:59 : Memory Programming ...
12:03:59 : Opening and parsing file: tf-a-stm32mp157c-dk2-trusted.stm32
12:03:59 : File : tf-a-stm32mp157c-dk2-trusted.stm32
12:03:59 : Size : 245364 Bytes
12:03:59 : Partition ID : 0x01
12:03:59 : Download in Progress:
12:04:00 : File download complete
12:04:00 : Time elapsed during download operation: 00:00:00.534
12:04:00 : RUNNING Program ...
12:04:00 : PartID: :0x01
12:04:00 : Start operation done successfully at partition 0x01
12:04:00 : Flashlayout Programming ...
12:04:00 : Running Flashlayout Partition ...
12:04:00 : Flashlayout partition started successfully
12:04:00 : Memory Programming ...
12:04:00 : Opening and parsing file: u-boot-stm32mp157c-dk2-trusted.stm32
12:04:00 : File : u-boot-stm32mp157c-dk2-trusted.stm32
12:04:00 : Size : 805514 Bytes
12:04:00 : Partition ID : 0x03
12:04:00 : Download in Progress:
12:04:01 : File download complete
12:04:01 : Time elapsed during download operation: 00:00:00.992
12:04:01 : RUNNING Program ...
12:04:01 : PartID: :0x03
12:04:01 : reconnecting the device ...
12:04:31 : Error: unable to reconnect the target device: time out expired
12:04:31 : Error: Start operation failed at partition 0x03
12:04:31 : Error: TSV flashing service failed
12:04:31 : Warning: Connection to device 0x500 is lost
12:04:32 : Disconnected from device.
PatrickF
Nov 24, 2020 14:03 UTC
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
MVENN.1
MVENN.1Author
Nov 24, 2020 17:03 UTC
Hi PatrickF(ST Employee)
Thank you for reply
I am using 5V/2A power supply. And also red led Blink continue.
can you just tell the where is the mistake i did.
Thank you.
MVENN.1
MVENN.1Author
Nov 25, 2020 11:01 UTC
Hi
Thank you for given this information.
I can able to flash the image on SD card in STM32CubeProgrammer in Windows.
After Booting( ON position ) i am getting default images like
0693W000005CbPRQA0.jpg0693W000005CbQAQA0.jpgAfter that this image only showing last 10 min onwards
i am not getting this image down one .
0693W000005CbRNQA0.jpg any one can reply.
Thanks.
Olivier GALLIEN
Nov 25, 2020 11:05 UTC
Hi @MVENN.1​
Very first boot after flash may take some time because there is file system uncompressed operation.
10min looks anyway very long.
Please plug a cable to get serial console and look what happen there
Olivier
MVENN.1
MVENN.1Author
Nov 25, 2020 11:48 UTC
Hi Oliver GALLIEN (ST Emplloyee )
How to plug the cable on to the PC.
Thanks.
Olivier GALLIEN
Nov 25, 2020 15:03 UTC
Hi @MVENN.1​
Which tsv did you load on target ?
Are you sure flashload completed with success ?
Olivier
MVENN.1
MVENN.1Author
Nov 25, 2020 15:58 UTC
Hi Olivier GALLIEN ( ST Employee )
I am loading E:\Shared_floder_window\stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12\images\stm32mp1\flashlayout_st-image-weston\trusted
tsv file FlashLayout_sdcard_stm32mp157c-dk2-trusted.tsv
Binary path :E:\Shared_floder_window\stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12\images\stm32mp1
21:11:10 : USB speed : High Speed (480MBit/s)
21:11:10 : Manuf. ID : STMicroelectronics
21:11:10 : Product ID : DFU in HS Mode @Device ID /0x500, @Revision ID /0x0000
21:11:10 : SN : 0034001A3438510438333630
21:11:10 : FW version : 0x0110
21:11:10 : Device ID : 0x0500
21:11:24 : Start Embedded Flashing service
21:11:24 : Memory Programming ...
21:11:24 : Opening and parsing file: tf-a-stm32mp157c-dk2-serialboot.stm32
21:11:24 : File : tf-a-stm32mp157c-dk2-serialboot.stm32
21:11:24 : Size : 237896 Bytes
21:11:24 : Partition ID : 0x01
21:11:24 : Download in Progress:
21:11:25 : File download complete
21:11:25 : Time elapsed during download operation: 00:00:00.490
21:11:25 : RUNNING Program ...
21:11:25 : PartID: :0x01
21:11:25 : Start operation done successfully at partition 0x01
21:11:25 : Flashlayout Programming ...
21:11:25 : Running Flashlayout Partition ...
21:11:25 : Flashlayout partition started successfully
21:11:25 : Memory Programming ...
21:11:25 : Opening and parsing file: u-boot-stm32mp157c-dk2-trusted.stm32
21:11:26 : File : u-boot-stm32mp157c-dk2-trusted.stm32
21:11:26 : Size : 904820 Bytes
21:11:26 : Partition ID : 0x03
21:11:26 : Download in Progress:
21:11:27 : File download complete
21:11:27 : Time elapsed during download operation: 00:00:00.993
21:11:27 : RUNNING Program ...
21:11:27 : PartID: :0x03
21:11:27 : reconnecting the device ...
21:11:30 : USB speed : High Speed (480MBit/s)
21:11:30 : Manuf. ID : STMicroelectronics
21:11:30 : Product ID : USB download gadget@Device ID /0x500, @Revision ID /0x2000, @Name /STM32MP157CAC Rev.B,
21:11:30 : SN : 0034001A3438510438333630
21:11:30 : FW version : 0x0110
21:11:30 : Device ID : 0x0500
21:11:30 : Start operation done successfully at partition 0x03
21:11:30 : Memory Programming ...
21:11:30 : Opening and parsing file: tf-a-stm32mp157c-dk2-trusted.stm32
21:11:31 : File : tf-a-stm32mp157c-dk2-trusted.stm32
21:11:31 : Size : 233800 Bytes
21:11:31 : Partition ID : 0x04
21:11:31 : Download in Progress:
21:11:31 : File download complete
21:11:31 : Time elapsed during download operation: 00:00:00.163
21:11:31 : RUNNING Program ...
21:11:31 : PartID: :0x04
21:11:31 : Start operation done successfully at partition 0x04
21:11:31 : Memory Programming ...
21:11:31 : Opening and parsing file: tf-a-stm32mp157c-dk2-trusted.stm32
21:11:31 : Partition ID : 0x05
21:11:31 : Time elapsed during download operation: 00:00:00.132
21:11:31 : PartID: :0x05
21:11:31 : Start operation done successfully at partition 0x05
21:11:31 : Opening and parsing file: u-boot-stm32mp157c-dk2-trusted.stm32
21:11:31 : File : u-boot-stm32mp157c-dk2-trusted.stm32
21:11:31 : Size : 904820 Bytes
21:11:31 : Partition ID : 0x06
21:11:31 : Time elapsed during download operation: 00:00:00.483
21:11:31 : PartID: :0x06
21:11:32 : Start operation done successfully at partition 0x06
21:11:32 : Memory Programming ...
21:11:32 : Opening and parsing file: st-image-bootfs-openstlinux-weston-stm32mp1.ext4
21:11:32 : File : st-image-bootfs-openstlinux-weston-stm32mp1.ext4
21:11:32 : Size : 64 MBytes
21:11:32 : Partition ID : 0x21
21:11:32 : Download in Progress:
21:12:19 : File download complete
21:12:19 : Time elapsed during download operation: 00:00:46.408
21:12:19 : RUNNING Program ...
21:12:19 : PartID: :0x21
21:12:19 : Start operation done successfully at partition 0x21
21:12:19 : Memory Programming ...
21:12:19 : Opening and parsing file: st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
21:12:19 : File : st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
21:12:19 : Size : 16 MBytes
21:12:19 : Partition ID : 0x22
21:12:19 : Download in Progress:
21:12:31 : File download complete
21:12:31 : Time elapsed during download operation: 00:00:11.629
21:12:31 : RUNNING Program ...
21:12:31 : PartID: :0x22
21:12:31 : Start operation done successfully at partition 0x22
21:12:31 : Memory Programming ...
21:12:31 : Opening and parsing file: st-image-weston-openstlinux-weston-stm32mp1.ext4
21:12:35 : File : st-image-weston-openstlinux-weston-stm32mp1.ext4
21:12:35 : Size : 407630 KBytes
21:12:35 : Partition ID : 0x23
21:12:35 : Download in Progress:
21:17:34 : File download complete
21:17:34 : Time elapsed during download operation: 00:04:58.568
21:17:34 : RUNNING Program ...
21:17:34 : PartID: :0x23
21:17:34 : Start operation done successfully at partition 0x23
21:17:34 : Memory Programming ...
21:17:34 : Opening and parsing file: st-image-userfs-openstlinux-weston-stm32mp1.ext4
21:17:37 : File : st-image-userfs-openstlinux-weston-stm32mp1.ext4
21:17:37 : Size : 128 MBytes
21:17:37 : Partition ID : 0x24
21:17:37 : Download in Progress:
21:19:12 : File download complete
21:19:12 : Time elapsed during download operation: 00:01:35.201
21:19:12 : RUNNING Program ...
21:19:12 : PartID: :0x24
21:19:12 : Start operation done successfully at partition 0x24
21:19:12 : Flashing service completed successfully
21:23:35 : Start Embedded Flashing service
21:23:35 : Flashing service completed successfully
21:24:00 : Start Embedded Flashing service
21:24:00 : Flashing service completed successfully
In console
UPLOAD ... done
Ctrl+C to exit ...
UPLOAD ... done
Ctrl+C to exit ...
##DOWNLOAD ... OK
Ctrl+C to exit ...
UPLOAD ... done
Ctrl+C to exit ...
UPLOAD ... done
Ctrl+C to exit ...
##################################################DOWNLOAD ... OK
Ctrl+C to exit ...
UPLOAD ... done
Ctrl+C to exit ...
UPLOAD ... done
Ctrl+C to exit ...
################Phase=END
DOWNLOAD ... OK
Ctrl+C to exit ...
UPLOAD ... done
Ctrl+C to exit ...
UPLOAD ... done
Ctrl+C to exit ...
UPLOAD ... done
Ctrl+C to exit ...
UPLOAD ... done
Ctrl+C to exit ...
this one please check it. I connected USB keyboard also Ctrl+C not taken.
Thanks.
Olivier GALLIEN
Nov 25, 2020 16:08 UTC
All looks good.
Now please share complete Linux boot log ( preferably using "Attach file "feature )
Olivier
MVENN.1
MVENN.1Author
Nov 25, 2020 17:07 UTC
Through windows ( STM32CubeProgrammer 2.5.0 ) only I am flashing the image.
please check it.
MVENN.1
MVENN.1Author
Nov 26, 2020 09:19 UTC
please check the below log file in Linux
Update me i really struct this probelm.
moveon@moveon-VirtualBox:/$ mkdir /home/moveon/STM32MPU_workspace
moveon@moveon-VirtualBox:/$ mkdir /home/moveon/STM32MPU_workspace/STM32MPU-Tools
moveon@moveon-VirtualBox:/$ ls
bin  cdrom etc  lib  lib64  lost+found mnt proc run  snap swapfile tmp var
boot dev  home lib32 libx32 media    opt root sbin srv  sys    usr
moveon@moveon-VirtualBox:/$ cd /home/moveon/STM32MPU_workspace/STM32MPU-Tools
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MPU-Tools$ ls
en.stm32cubeprg-lin_v2-6-0.zip
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MPU-Tools$ unzip en.stm32cubeprg-lin_v2-6-0.zip
Archive: en.stm32cubeprg-lin_v2-6-0.zip
  creating: jre/
  creating: jre/bin/
 inflating: SetupSTM32CubeProgrammer-2.6.0.exe
 inflating: SetupSTM32CubeProgrammer-2.6.0.linux
en.stm32cubeprg-lin_v2-6-0.zip jre SetupSTM32CubeProgrammer-2.6.0.exe SetupSTM32CubeProgrammer-2.6.0.linux
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MPU-Tools$ ./SetupSTM32CubeProgrammer-2.6.0.linux
chdir /home/moveon/STM32MPU_workspace/STM32MPU-Tools/.
current dir /home/moveon/STM32MPU_workspace/STM32MPU-Tools
Command line arguments:
Installation started
Framework: 1.8.0_192-BellSoft-b03 (Oracle Corporation)
Platform: ubuntu_linux,version=5.4.0-53-generic,arch=x64,symbolicName=null,javaVersion=1.8.0_265
Installation finished
WARNING: using deprecated Desktop Entry key Encoding with value UTF-8
[ Writing the uninstaller data ... ]
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MPU-Tools$ export PATH=/home/moveon/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin//:$PATH
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MPU-Tools$ STM32_Programmer_CLI --h
            STM32CubeProgrammer v2.6.0
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MPU-Tools$ sudo apt-get install libusb-1.0-0
[sudo] password for moveon:
Reading package lists... Done
Building dependency tree
Reading state information... Done
libusb-1.0-0 is already the newest version (2:1.0.23-2build1).
The following packages were automatically installed and are no longer required:
 libdlt2 libfprint-2-tod1 openjfx-source
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 40 not upgraded.
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MPU-Tools$ mkdir /home/moveon/STM32MPU_workspace/STM32MP15-Ecosystem-v2.1.0
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MPU-Tools$ cd ..
moveon@moveon-VirtualBox:~/STM32MPU_workspace$ ls
STM32MP15-Ecosystem-v2.1.0 STM32MPU-Tools
moveon@moveon-VirtualBox:~/STM32MPU_workspace$ mkdir Starter-Package
moveon@moveon-VirtualBox:~/STM32MPU_workspace$ cd STM32MP15-Ecosystem-v2.1.0/
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MP15-Ecosystem-v2.1.0$ mkdir Starter-Package
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MP15-Ecosystem-v2.1.0$ ls
Starter-Package
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MP15-Ecosystem-v2.1.0$ cd Starter-Package/
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MP15-Ecosystem-v2.1.0/Starter-Package$ ls
en.FLASH-stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12.tar.xz
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MP15-Ecosystem-v2.1.0/Starter-Package$ tar xvf en.FLASH-stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12.tar.xz
stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12/
stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12/images/
stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12/images/stm32mp1/
stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12/images/stm32mp1/st-image-weston-openstlinux-weston-stm32mp1.license
stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12/images/stm32mp1/st-image-weston-openstlinux-weston-stm32mp1_nand_4_256_multivolume.ubi
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MP15-Ecosystem-v2.1.0/Starter-Package$ STM32_Programmer_CLI -l usb
===== DFU Interface  =====
Total number of available STM32 device in DFU mode: 1
 Device Index      : USB1
 USB Bus Number     : 001
 USB Address Number   : 002
 Serial number     : 0034001A3438510438333630
 Firmware version    : 0x0110
 Device ID       : 0x0500
en.FLASH-stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12.tar.xz stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MP15-Ecosystem-v2.1.0/Starter-Package/stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12/images$ cd stm32mp1/
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MP15-Ecosystem-v2.1.0/Starter-Package/stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12/images/stm32mp1$ ls
arm-trusted-firmware                 st-image-userfs-openstlinux-weston-stm32mp1.manifest
bootloader                      st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
flashlayout_st-image-weston              st-image-weston-openstlinux-weston-stm32mp1.ext4
optee                         st-image-weston-openstlinux-weston-stm32mp1.license
scripts                        st-image-weston-openstlinux-weston-stm32mp1-license_content.html
st-image-bootfs-openstlinux-weston-stm32mp1.ext4   st-image-weston-openstlinux-weston-stm32mp1.manifest
st-image-bootfs-openstlinux-weston-stm32mp1.manifest st-image-weston-openstlinux-weston-stm32mp1_nand_4_256_multivolume.ubi
moveon@moveon-VirtualBox:~/STM32MPU_workspace/STM32MP15-Ecosystem-v2.1.0/Starter-Package/stm32mp1-openstlinux-5-4-dunfell-mp1-20-11-12/images/stm32mp1$ STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-weston/FlashLayout_sdcard_stm32mp157c-dk2-trusted.tsv
Manuf. ID  :
Product ID :
SN     :
FW version : 0x0110
IAP
Error: TSV files are only supported for STM32MP
Thank.
Olivier GALLIEN
Nov 26, 2020 09:43 UTC
Hi @MVENN.1​
First path flashlayout_st-image-weston/FlashLayout_sdcard_stm32mp157c-dk2-trusted.tsv is strange
might be flashlayout_st-image-weston/trusted/FlashLayout_sdcard_stm32mp157c-dk2-trusted.tsv
But this do not explain the connection problem.
Looks like you loose target connection between :
and
Did you change anything in between ?
Can you check "STMicroelectronics DFU " device is still visible from you Virtual Box prior to launch the flashload command ?
Else I'm a bit puzzled since you previously report success in flashing but stuck in boot and I requested linux boot log console.
Please clarify.
Olivier
MVENN.1
MVENN.1Author
Nov 26, 2020 10:30 UTC
Hi Olivier GALLIEN (ST Employee )
Thank you for reply
Actually previous report is flashing succeed in windows platform.
I now flashing Linux(Ubuntu20.04 its getting error like
0693W000005CjwJQAS.jpgplease check it.
Thanks.
MVENN.1
MVENN.1Author
Nov 26, 2020 10:46 UTC
Thank you for reply
I now flashing Linux(Ubuntu20.04 its getting error like0693W000005CkAfQAK.jpg
please check it .
Thanks.
