Olivier GALLIEN
Olivier GALLIENBest answer
Nov 24, 2020 07:53 UTC
Hi @MVENN.1​ ,
Only the last version 2.6 is supported on Ubuntu 20.04.
And since this version the JRE is bundle inside STM32CubeProgrammer and no longer need extra JRE package.
Olivier
KnarfB
Nov 21, 2020 11:58 UTC
There is a detailed description in the wiki. Works fine for me. The latest version 2.6. should also have some improvements.
PatrickF
Nov 23, 2020 07:14 UTC
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
MVENN.1
MVENN.1Author
Nov 23, 2020 09:04 UTC
I can able to flash the image in SD card through Windows only but only two images screenshots getting.
MVENN.1
MVENN.1Author
Nov 23, 2020 13:43 UTC
when i am launch through the linux its getting errors this please once check.
Error: Unable to access jarfile /STM32CubeProgrammerLauncher
how to i open STM32Cubeprogramming in ubuntu.
MVENN.1
MVENN.1Author
Nov 23, 2020 14:10 UTC
moveon@moveon-VirtualBox:/usr/local/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin$ sudo ./STM32CubeProgrammer
Error: Could not find or load main class com.st.app.Main
This message i am getting
Olivier GALLIEN
Nov 23, 2020 21:50 UTC
Hi @MVENN.1​ ,
Which version of Ubuntu are you using ?
You should have a icon on the desktop.
You may have to right click / select "Allow Launching".
Then double click on this should launch CubeProg.
Could you also try to run the CLI for a check ?
Olivier
MVENN.1
MVENN.1Author
Nov 24, 2020 04:54 UTC
HI Olivier GALLIEN (ST Employee)
I am using Ubuntu 20.04 version.
on the desktop icon is there but it doesn't open when i am click to "Allow Launching"
it shows like
0693W000005CNwMQAW.jpg0693W000005CNwCQAW.jpgThanks
ArmandG
Nov 24, 2020 07:06 UTC
Hi @MVENN.1​ ,
First of all, did you do all these prerequisites:
PC $> sudo apt-get install openjdk-8-jre-headless
PC $> sudo update-alternatives --config java
Select the java-8-openjdk configuration.
PC $> sudo apt purge openjfx
PC $> sudo apt install openjfx=8u161-b12-1ubuntu2 libopenjfx-jni=8u161-b12-1ubuntu2 libopenjfx-java=8u161-b12-1ubuntu2
PC $> sudo apt-mark hold openjfx libopenjfx-jni libopenjfx-java
Then, did you well choose "$HOME/STM32MPU_workspace/STM32MPU-Tools/STM32CubeProgrammer-2.5.0" as path when installing the launcher ? And is it working when running "$HOME/STM32MPU_workspace/STM32MPU-Tools/STM32CubeProgrammer-2.5.0/./STM32CubeProgrammer" ?
Also, does the CLI is working ? (what do you get when running "$HOME/STM32MPU_workspace/STM32MPU-Tools/STM32CubeProgrammer-2.5.0/./STM32_Programmer_CLI")
Armand
Olivier GALLIEN
Hi @MVENN.1​ ,
Olivier
MVENN.1
MVENN.1Author
Nov 24, 2020 08:05 UTC
Hi Olivier GALLIEN (ST Employee )
Thank you for reply.
I am just installer STM32Cubeprogrammer 2.5.0 version in Ubuntu 20.04
can you please give steps to install the 2.6 version.
Olivier GALLIEN
Nov 24, 2020 09:05 UTC
Hi @MVENN.1​ ,
Download STM32CubePrg-Lin package here : https://www.st.com/en/development-tools/stm32cubeprog.html
Olivier
MVENN.1
MVENN.1Author
Nov 24, 2020 10:02 UTC
Hi Olivier GALLIEN (ST Employee)
Thanks its working fine.
when I launch and connect the device it shows like
I installed USB port also.
MVENN.1
MVENN.1Author
Nov 24, 2020 13:27 UTC
I can able to install and connecting is ok but when i connect the device it showing like this please once check it.
0693W000005CT41QAG.jpgThank
MVENN.1
MVENN.1Author
Nov 24, 2020 13:41 UTC
please check i getting this warning
MVENN.1
MVENN.1Author
