Senior
Apr 14, 2026 5:05 PM UTC
WiFi or WiFi+BT modules architecture and parts recommendations
We are looking for a WiFi module or preferably a WiFi + BT module to be used in a battery-operated device where audio files are recorded onto a uSD card and whenever required they are downloaded through WiFi or BT link to a PC. For context, the audio files are 20MB in size.
These are the main specs:
- pre-certified module: WiFi or WiFi+BT
- highly reliable for mass production
- uSD card interface (specific for audio and files)
- means to record and play back the audio files
- low-power
- compact & SMD
- straightforward to integrate from a firmware perspective (library available) and well supported in terms of documentation and ecosystem.
Could you please make recommendations:
- for such suitable modules?
- for alternative system architecture using ST products and ecosystem to implements such device?
Thank you
Ricko
Andrew Neil
Andrew NeilBest answer
Apr 14, 2026 5:19 PM UTC
ST's only module with both WiFi and BLE is the ST67W series:
https://www.st.com/en/wireless-connectivity/wi-fi-products.html
This is a coprocessor module - it needs a separate Host microcontroller.
ST's MCUs with built-in BLE are the STM32WBx series:
https://www.st.com/en/microcontrollers-microprocessors/stm32-wireless-mcus/products.html
There are no MCUs with WiFi.
Andrew Neil
RickoAuthor
Senior
Apr 14, 2026 7:47 PM UTC
Thank you @Andrew Neil
what would you recommend as the lowest cost micro that can record to uSD and playback audio files?
Thank you
Andrew Neil
Apr 15, 2026 9:37 AM UTC
An SD card (micro or otherwise) can be accessed via SPI - so any microcontroller with SPI ...
https://www.st.com/en/development-tools/st-mcu-finder-pc.html
https://www.st.com/en/development-tools/stm32-finder.html
https://www.st.com/content/st_com/en/stm32-mcu-developer-zone/mcu-portfolio.html
Distributors often have good parametric search tools ...
Andrew Neil
Apr 15, 2026 2:37 PM UTC
Follow-on question focussing on audio capabilities split to new thread:
Microcontroller with some kind of audio I/O capability ?
@Ricko If Audio is key, note that ST Microcontrollers only have BLE - not "Classic" BT.
Most "Bluetooth" audio is "Classic".
If the WiFi/BLE part of your question is now resolved, please mark the solution.
RickoAuthor
Senior
Apr 16, 2026 9:57 AM UTC
