antonius
Decoding bmp ?
  • April 11, 2014
  • 90 replies
  • 37501 views
Posted on April 11, 2014 at 11:21
Guys,
Does anyone of you have experience on decoding bmp ?
I want to display bmp file to my LCD...
Any clues ?
thanks
#i-have-a-clue
    antonius
    antoniusAuthor
    April 28, 2014
    Posted on April 28, 2014 at 16:25
    Does you display go white when you write 0xFFFF as the colour? If it doesn't I'd look more carefully at how it's set up and connected.
    LCD_Clear(0xFFFF);
    antonius
    antoniusAuthor
    Posted on April 28, 2014 at 16:35
    It's not going to be white, looks like transparent ?
    April 28, 2014
    Posted on April 28, 2014 at 17:07
    Ok, so what's the right RGB colour space number for White?
    antonius
    antoniusAuthor
    Posted on April 29, 2014 at 00:24
    Well, I have no clue on how to know white color for this LCD ?
    How to test white color for it ? thanks
    April 28, 2014
    Posted on April 29, 2014 at 01:30
    Well I think there is a problem with your display, or it's attachment. What you should probably do is test the primary colours, and try reading back the values programmed into the buffer.
    /* LCD colour */
    #define White 0xFFFF
    #define Black 0x0000
    #define Blue 0x001F
    #define Red 0xF800
    #define Magenta 0xF81F
    #define Green 0x07E0
    #define Cyan 0x7FFF
    #define Yellow 0xFFE0
    antonius
    antoniusAuthor
    Posted on April 29, 2014 at 01:36
    In this function ?
    void LCD_Clear(uint16_t Color)
    uint32_t index=0;
    LCD_SetCursor(0,0);
    LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
    for(index=0;index<76800;index++)
    LCD_RAM=Color;
    printf(Color);
    antonius
    antoniusAuthor
    Posted on April 29, 2014 at 01:43
    I've made a test function :
    void LCD_Color_test()
    LCD_Clear(Black);
    delay_ms(1000);
    LCD_Clear(White);
    delay_ms(1000);
    LCD_Clear(Grey);
    delay_ms(1000);
    LCD_Clear(Blue);
    delay_ms(1000);
    LCD_Clear(Blue2);
    delay_ms(1000);
    LCD_Clear(Red);
    delay_ms(1000);
    LCD_Clear(Magenta);
    delay_ms(1000);
    LCD_Clear(Green);
    delay_ms(1000);
    LCD_Clear(Cyan);
    delay_ms(1000);
    LCD_Clear(Yellow);
    Can you display white properly in your LCD ? thanks
    antonius
    antoniusAuthor
    Posted on April 29, 2014 at 01:51
    It can do Grey, but can not do White, why is it ?
    April 29, 2014
    Posted on April 29, 2014 at 02:13
    Pretty sure the printf() there isn't appropriate.
    Yes, start by filling the panel with colour, and confirm those actually work, or if the colour is wrong.
