antonius
Decoding bmp ?
  • April 11, 2014
  • 90 replies
  • 37501 views
Posted on April 11, 2014 at 11:21
Guys,
Does anyone of you have experience on decoding bmp ?
I want to display bmp file to my LCD...
Any clues ?
thanks
#i-have-a-clue
    April 29, 2014
    Posted on April 29, 2014 at 02:17
    Can you display white properly in your LCD ?
    I will check tomorrow, but pretty sure it does.
    April 29, 2014
    Posted on April 29, 2014 at 03:03
    The SSD1289 has a Transparency bit in Register 0x11, but it's application with respect to the data stream is not discussed further.
    You could presumably do a test
    if (rgb == 0xFFFF) rgb = 0xFFFE;
    antonius
    antoniusAuthor
    Posted on April 29, 2014 at 08:43
    Like this :
                  rgb = ((rgb & 0xF80000) >> 8) | ((rgb & 0x00FC00) >> 5) | ((rgb & 0x0000F8) >> 3);
                  LCD_SetPoint(y/3, x/3, rgb);
    I got no response, still dot dot white on the screen...
    April 29, 2014
    Posted on April 29, 2014 at 09:18
    No like this, do you have no sense of logic and sequence?
    rgb = ((rgb & 0xF80000) >> 8) | ((rgb & 0x00FC00) >> 5) | ((rgb & 0x0000F8) >> 3); // convert to colour space of display
    if (rgb == 0xFFFF) rgb = 0xFFFE; // address transparent/white issue
    LCD_SetPoint(y/3, x/3, rgb); // paint dot on screen
    antonius
    antoniusAuthor
    Posted on April 29, 2014 at 09:52
    it's changing to FFFE but not in a solid LCD, there are some black spots on LCD...why is it ?
    antonius
    antoniusAuthor
    Posted on April 29, 2014 at 09:55
    solid color with this :
    if (rgb == 0xFFFF) rgb = 0xF7DE;
    antonius
    antoniusAuthor
    Posted on April 29, 2014 at 09:57
    or
    if (rgb == 0xFFFF) rgb = 0xFFFD; works allright..
    April 29, 2014
    Posted on April 29, 2014 at 21:07
    You are asking me questions about a board and screen that I don't have, and cannot independently verify/test.
    It is possible that x/3 or y/3 exceed the dimensions of the display.
    April 29, 2014
    Posted on April 29, 2014 at 23:08
    The SSD1298 on the STM32F407 does appear to display the primary colours properly, and doesn't have issues with transparent/clear 0xFFFF. Painted the Blue/White flag without issue.
    antonius
    antoniusAuthor
    Posted on April 30, 2014 at 00:22
    may be I need to change my initialization code for handling this 0xFFFF issue ? thanks
