Oct 28, 2024 10:33 AM UTC
UART communication between Raspberry Pi 4 and stm32f411re
Hi, i want the communication between stm32f411re board and raspberry pi 4. i tried to do with uart2 through USB cable it is working fine. but sometimes it is not able to communicate properly. there is a delay while communicating sometimes. will i2c or spi communication works with USB cable to communicate. which is better and i want the one efficient to work as i want both ways communication.
suhfiBest answer
Nov 5, 2024 12:33 PM UTC
Okay sure, the problem is with the delay in the communication of stm32 Nucleo board and raspberry pi through UART. but later i have understood that the delay is not with the communication but with the motors drivers and working of that. Thank you for your time.
Andrew Neil
Oct 28, 2024 10:40 AM UTC
There no inherent reason why that should happen with a UART connection.
You need to find out what's causing this delay - it must be something elsewhere in your system.
Changing to some other transport won't fix that.
Have you tried using the Raspberry Pi's hardware UART ?
PS:
Please give more details of that.
I assume you mean a USB-to-UART cable/adaptor somewhere?
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
suhfiAuthor
Oct 28, 2024 10:52 AM UTC
No, i didn't do the communication by connecting the gpio pins, but from the usb cable. there is a delay for sure. i didn't mention any delay with that, then why am i facing delay with the comunication.
Andrew Neil
Oct 28, 2024 10:54 AM UTC
Again, you need to give more details.
How, exactly, are you making this USB connection?
Show a schematic.
Post photographs.
What, exactly, is the "stm32f411re board" you are using?
Is it still the same as this:
https://community.st.com/t5/stm32-mcus-products/communication-between-nucleo-f411re-and-raspberry-pi-using-st/m-p/721443
mƎALLEm
Oct 28, 2024 10:50 AM UTC
Related to this thread: https://community.st.com/t5/stm32-mcus-products/communication-between-nucleo-f411re-and-raspberry-pi-using-st/td-p/721443
Need to clarify this statement. From which side? STM32 delays the transmit or Raspberry-Pi?
Andrew Neil
Oct 28, 2024 12:08 PM UTC
Indeed.
@suhfi Also, how much of a delay is it?
How do you observe this delay?
Andrew Neil
Oct 28, 2024 10:51 AM UTC
suhfiAuthor
Oct 28, 2024 12:05 PM UTC
Thank you for the replies, i did solve the problem.
Andrew Neil
Oct 28, 2024 12:13 PM UTC
Great - so, for the benefit of future readers, what was the problem?
Please describe how you solved it, and then mark that as the solution:
https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256
suhfiAuthorBest answer
