The content you are looking for has been archived. View related content below.
on
2024-01-10
6:34 AM
- edited on
2025-11-26
6:55 AM
by
Laurids_PETERSE
Common causes for issues during the install and activation process, are network communication problems.
Try to double check the settings of the elements above, then temporarily deactivate them. If possible, manually add an exception to allow NanoEdge AI Studio to operate.
If NanoEdge AI Studio loads infinitely on startup, check the environment variables:
To access the environment variables, search for "environment variable" in the windows search bar and click on "environment variables".
| ST API for library compilation: | 52.178.13.227 | URL: https://api.nanoedgeaistudio.net |
For persistent activation issues, (for example, when a valid NanoEdge AI license key fails to be recognized as valid despite all efforts) an offline activation may be required.
For any other issues, contact us via mail on edge.ai@st.com
