Nov 4, 2024 5:29 PM UTC
STM32CubeProgrammer crashes when connect STM32F401CCU6
I just get a STM32F401CCU6 board (a real one) but now when I try to connect my board on STM32CubeProgrammer the application crahses... and when is unplug my board the application work again fine...
It also look like my board is stuck in bootloader mode ( only the red led lights up)
I don't know if someone could help me...
Thank you
Andrew Neil
Nov 4, 2024 5:43 PM UTC
So what board is it?
And what version of CubeProgrammer?
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
TotouanAuthor
Nov 4, 2024 6:25 PM UTC
As I said, it is a STM32F401CCU6 board  (a stmicroelectronic)
ANd for the version of CubeProgrammer :
Andrew Neil
Nov 5, 2024 9:08 AM UTC
That's just the chip - not the board.
Is it a Discovery board? a Nucleo board? an EV board? other?
gbm
Nov 5, 2024 10:22 AM UTC
I assume it's BlackPill. I think the problem is not related to the board/chip at all. CubeProgrammer frequently installs incorrectly. Then it tries (sometimes even with success) to display some strange error messages about missing components or refuses to execute some actions. That's probably the case here.
gbm
Nov 4, 2024 6:40 PM UTC
And why don't you use the current version, 2.17?
TotouanAuthor
Nov 4, 2024 6:45 PM UTC
Okay I will try with the latest version
Thanks for your help
TotouanAuthor
Nov 4, 2024 7:01 PM UTC
Okay now I am running on the 2.17 version but there is still the same problem
TotouanAuthor
Nov 5, 2024 11:45 AM UTC
Sorry i didn't understood, here is the link from the product i bought : https://www.amazon.fr/dp/B0CLD5FG62?ref=ppx_yo2ov_dt_b_fed_asin_title
Andrew Neil
Nov 5, 2024 12:04 PM UTC
Always best to provide a link at the start - so that everyone knows exactly what you're talking about
That's a 3rd-party board - not an ST board - and there's a risk that it may not have a genuine STM32.
Have you contacted RUIZHI for support? Do they claim that it should work with CubeProgrammer?
Do you have that "WeAct" bootloader?
TotouanAuthor
Nov 5, 2024 4:51 PM UTC
Thank you for your help, I will try what you told me to do
And yes it is written WeAct on the back of the board if it is what you meant.
TotouanAuthor
Nov 5, 2024 4:55 PM UTC
Euh I made a little mistake... I clicked on solved... possible to remove that ?
Andrew Neil
Nov 5, 2024 5:00 PM UTC
TotouanAuthor
Nov 5, 2024 7:08 PM UTC
Thank you
