Jul 29, 2025 06:38 UTC
"Range [0,-1) out of bounds for length 48" trying to open Debug Configuration
Hello, I'm trying to set the debug configuration of my project, but I cannot open the debug file under C/C++ Application. Besides, running this project was not successful either.
I have tried switching workspace and uninstalling IDE, but neither worked.
Can anyone help me solve my problem? Thank you very much.
Imen.DBest answer
Aug 1, 2025 12:33 UTC
Hello @Levy-hy ,
We have reproduced this issue with CubeIDE 1.19 and I escalated it to our CubeIDE team for analysis (internal ticket number: 215198).
PS: Ticket number: 215198 is an internal tracking number and is not accessible or usable by customers.
mbarg.1
Senior III
Jul 29, 2025 07:55 UTC
Version of STM32CubeIde?
Version 1.18 are buggy - update to 1.19
Levy-hyAuthor
Jul 29, 2025 08:15 UTC
Mine is 1.19, already the latest one
Andrew Neil
Jul 29, 2025 07:59 UTC
Did you try pressing the 'Details' button?
The message says, "Out of bounds for length 48".
The name of your Debug Configuration is very long* - maybe it's too long?
Maybe try just shortening the name?
PS:
* The name certainly is over 48 characters!
Levy-hyAuthor
Jul 29, 2025 08:24 UTC
Details are the same. I tired to rename the project to make its name shorter, but it didn't work either.
Then I opened another project, and found its run configuration back to normal. So I assume the problem lies in the project. But the project is the example AI demo project of STM32N6 and I'm stuck here:(
Jul 29, 2025 08:37 UTC
@Levy-hy , Did you make any changes to the Demo project?
Check Project configuration, such as memory allocation and linker scripts are correctly configured.
You can also, perform a clean build of the project to ensure no corrupted files are causing this issue.
Jul 29, 2025 08:23 UTC
Hello @mbarg.1
Try follow the steps in this article : How to debug STM32N6 using STM32CubeIDE
Imen.DBest answer
Hello @Levy-hy ,
Aug 8, 2025 05:55 UTC
Hello Imen.D,
I am also facing the same issue . Is there a resolution to the issue available?
Ghofrane GSOURI
Aug 19, 2025 11:39 UTC
Hello @Levy-hy
As a workaround, try removing the following line from your .project file:
<nature>com.st.stm32cube.ide.mcu.MCUAppSProjectNature</nature>
You will be able to debug your project successfully.
THX
Ghofrane
