Mar 31, 2026 15:19 UTC
livetune Designer Source Code Compilation Error
Having issues compiling the source code found in the audio kit for the designer application.
C:\x-cube-audio-kit-v1-4-1\package\Projects\STM32H573I-DK\Applications\Livetune\STM32CubeIDE\Designer
After importing the project into STM32 Cube IDE when I attempt to build the source without changing anything I get the following error....
make -j22 all
arm-none-eabi-gcc -o "firmware.elf" @"objects.list" ../../../../../../../Middlewares/ST/STM32_Audio/Addons/PDM/Lib/libPDMFilter_CM33_GCC_wc32.a ../../../../../../../Middlewares/ST/Audio-Kit/lib/libAudioChainAlgos_CM33_GCC.a ../../../../../../../Middlewares/ST/Audio-Kit/lib/libAudioChain_CM33_GCC.a ../../../../../../../Drivers/CMSIS/DSP/Lib/libCMSISDSP_CM33_GCC.a -mcpu=cortex-m33 -T"../Project.ld" --specs=nosys.specs -Wl,-Map="firmware.map" -Wl,--gc-sections -static -L../../../../../../Drivers/CMSIS/DSP/Lib/GCC -L../../../../../../Middlewares/ST/STM32_Audio/Addons/PDM/Lib -Xlinker -no-wchar-size-warning -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -Wl,--start-group -lc -lm -Wl,--end-group
C:/ST/STM32CubeIDE_1.18.1/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.14.3.rel1.win32_1.0.100.202602081740/tools/bin/../lib/gcc/arm-none-eabi/14.3.1/../../../../arm-none-eabi/bin/ld.exe: ../../../../../../../Middlewares/ST/Audio-Kit/lib/libAudioChainAlgos_CM33_GCC.a(enh_src_asm.o)(asm_nr_fltr_frm): Unknown destination type (ARM/Thumb) in ../../../../../../../Middlewares/ST/Audio-Kit/lib/libAudioChainAlgos_CM33_GCC.a(enh_src.o)
../../../../../../../Middlewares/ST/Audio-Kit/lib/libAudioChainAlgos_CM33_GCC.a(enh_src.o): in function `s_fltr_frm':
C:/STM32/audio-kit/Firmware/Middlewares/ST/Audio-Kit/src/algos/nr/src/enh_src.c:2294:(.text.enh_main+0x202): dangerous relocation: unsupported relocation
C:/STM32/audio-kit/Firmware/Middlewares/ST/Audio-Kit/src/algos/nr/src/enh_src.c:2294:(.text.enh_main+0x324): dangerous relocation: unsupported relocation
C:/STM32/audio-kit/Firmware/Middlewares/ST/Audio-Kit/src/algos/nr/src/enh_src.c:2294:(.text.enh_main+0x738): dangerous relocation: unsupported relocation
C:/STM32/audio-kit/Firmware/Middlewares/ST/Audio-Kit/src/algos/nr/src/enh_src.c:2294:(.text.enh_main+0x858): dangerous relocation: unsupported relocation
C:/STM32/audio-kit/Firmware/Middlewares/ST/Audio-Kit/src/algos/nr/src/enh_src.c:2294:(.text.enh_main+0x932): dangerous relocation: unsupported relocation
C:/STM32/audio-kit/Firmware/Middlewares/ST/Audio-Kit/src/algos/nr/src/enh_src.c:2294:(.text.enh_main+0x9de): dangerous relocation: unsupported relocation
collect2.exe: error: ld returned 1 exit status
make[1]: *** [makefile:196: firmware.elf] Error 1
make: *** [makefile:189: all] Error 2
"make -j22 all" terminated with exit code 2. Build might be incomplete.
I can import and build the tuner and release source codes just fine. Just not the designer source code.
Any thoughts? Been trying to find the differences between the 3 projects but haven't found the issue yet.
Andrew Neil
Andrew NeilBest answer
Mar 31, 2026 15:27 UTC
So the actual error message is, "dangerous relocation: unsupported relocation"
Same message here:
https://community.st.com/t5/stm32cubeide-mcus/cubeide-2-1-0-system-stm32wl3x-o-dangerous-relocation/m-p/883226
Andrew Neil
Same message here:
mantwihAuthor
Mar 31, 2026 16:07 UTC
Hi Andrew,
Thanks for pointing me to that thread.
I am running STM32CubeIDE 2.1.1 using GNU tools for STM32 14.3.rel1.
Are we saying the solution would be go back to CubeIDE 2.1.0 and GNU tools 13.3?
mantwihAuthor
Mar 31, 2026 17:07 UTC
Okay installing GNU tools for STM32 release 13.3 worked and got the project building.
