CubeIDE 2.1.0: system_stm32wl3x.o dangerous relocation: unsupported relocation
  • March 3, 2026
  • 5 replies
  • 1325 views
I have created a project for the STM32WL33 several weeks ago, using the DEEPSTOP mode with context restoration provided by ST. Even if there are some pitfalls with this the project worked mostly fine. But after the update to STM32CubeIDE 2.1.0 I get a compilation error:
./System/Startup/cpu_context_switch.o(CPUcontextRestore): Unknown destination type (ARM/Thumb) in ./Core/Src/system_stm32wl3x.o
make: *** [makefile:89: Euris3-EHKV-WMBus.elf] Error 1
I've reverted the version to 2.0.0 and the error is gone.
Best answer by Andrew Neil
@RWalko wrote:
system_stm32wl3x.o
Same message here: Solved: system_stm32wb0x.c - dangerous relocation: unsupported relocation (CubeIDE, CubeMX).
@Ghofrane GSOURI - Internal Ticked 228023 raised by @Mahmoud Ben Romdhane
Ghofrane GSOURI
Hello @RWalko
Could you please provide your project?
THX
Ghofrane
RWalkoAuthor
Sorry, I cannot provide my project as it includes company code and I cannot quickly clean it up. If you can provide a safe data transfer possibility I may be able to send you the project.
Andrew Neil
Andrew NeilBest answer
@RWalko wrote:
system_stm32wl3x.o
gbm
That's simply a new wording for an old linker error message "undefined symbol". Some strange update happened to LD.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
Andrew Neil
Seems to be slightly different ?
The problem seems to the that the Assembler and/or Linker has become more picky about the specific details of the definition - the definition does exist, but is not qualified with this new %function directive requirement ?
Andrew Neil
From the ARM forums:
"Since binutils version 2.44, functions in assembly must include the assembler directive .type name, %function, otherwise they fail at linking."
binutils 2.44 and GCC 15.1.0 - dangerous relocation: unsupported relocation error when trying to build U-Boot.
See also: https://gcc.gnu.org/pipermail/gcc-help/2025-May/144189.html
And: https://lists.denx.de/pipermail/u-boot/2025-May/589101.html
HNish.2
Could you tell me how to write this in C?
Would I need to use inline assembly?
Andrew Neil
It seems to be purely an issue for assembler?
I think you need to start a separate thread of your own (this one is already marked as solved), giving a full description of your particular situation.
You can always give a link back to this thread, for context.
How to write your question to maximize your chances to find a solution
Andrew Neil
@Ghofrane GSOURI @Mahmoud Ben Romdhane
Another example of the same issue has just appeared - this time with H7 & X-CUBE-AUDIO-KIT:
livetune Designer Source Code Compilation Error
Andrew Neil
And another here: Unknown destination type (ARM/Thumb) linking error in cube ide
