Optimal MCU clock frequency to reduce EMI interference to co-exist GNSS receiver
For battery and small size system, STM32WLE5JC is next to a "patch antenna GNSS module", how you think about two choices?
1. Use low MCU clock frequency. MCU active for LONGER time, then finish the work and go to STOP2 with RTC on. I believe low MCU freq is less noisy (but noise duration is longer), right?
2. Use high MCU freq. MCU active for SHORTER time and then STOP2 with RTC on. I believe high freq is more noise (but noise duration is shorter), right?
TIA
