STM32H7 PC2_C and PC3_C GPIO not working
  • November 4, 2024
  • 11 replies
  • 2388 views
Originally a reply in this thread: https://community.st.com/t5/stm32cubemx-mcus/bug-cubemx-should-warn-h7-users-against-pc2-c-pc3-c-pitfalls/td-p/708817
What's wrong with PC2_C and PC3_C???  I am using them as normal GPO on my board, but it's not working, while PC0 and PC1 are working, same initialization and HAL_GPIO_WritePin() operation.
Peter
Best answer by mƎALLEm
How did you configure the internal switches?
They need to be closed. So their respective values of PCXSO in SYSCFG_PMCR register needs to be 0.
+ Read this article: https://community.st.com/t5/stm32-mcus/faq-default-state-of-stm32h7-switches-connecting-pxy-c-and-pxy/ta-p/49300
What is the exact STM32H7 part number you are using?
mƎALLEm
mƎALLEmBest answer
Peter3718Author
it seems i misled by the H755 user manual.
please check H755 rm0399, page 587
it states 0 is close, actually 1 is close.
I read PMCR, 0x300 0000, and PC2, PC3 GPIO function is normal now.
0 is default register value from reset, but GPIO is not working.
I think CUBEMX need to generate these switch code if GPIO function is selected.
Peter
mƎALLEm
The default status of the switches depends on the package:
Also, read this article: https://community.st.com/t5/stm32-mcus/faq-default-state-of-stm32h7-switches-connecting-pxy-c-and-pxy/ta-p/49300
Andrew Neil
The original thread stated "speed limitations" - check the datasheet for details.
Did you review the linked threads?
What speeds are you trying to achieve?
What is your configuration?
Please show your schematic
What, exactly, is "not working" ?
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
Peter3718Author
Thanks Andrew,
It seems i found an error of your user manual. please see above reply.
Peter
Andrew Neil
@Peter3718 wrote:
Thanks Andrew,
Not my manual!
https://community.st.com/t5/community-guidelines/st-community-welcome-guide/ta-p/575223#:~:text=How%20to%20identify%20ST%20employees%C2%A0
