Stm32f401 Nucleo Board with ISM330DHCX and BlueNRG-M2SA
Hi
I am trying to send data from the ISM330DHCX sensor to BLE (BlueNRG-M2SA) on the STM32F401 Nucleo board. I have installed the XCUBES_MEMS1 software and successfully tested the LED example via BLE. Now, I want to transmit the ISM330DHCX sensor data through a BLE app. Can anyone guide me.
How to send sensor data from the ISM330DHCX to a Bluetooth app using the X-NUCLEO-BNRG2A1 interface with an STM32F401RE?
Andrew Neil
Divide & conquer!
You have 2 entirely separate tasks here:
  1. How to use the ISM330DHCX IMU:
    https://www.st.com/en/mems-and-sensors/ism330dhcx.html
  2. How to use the X-NUCLEO-BNRG2A1:
    https://www.st.com/en/ecosystems/x-nucleo-bnrg2a1.html
Get them working separately first, then bring them together.
The above Product Pages will point you to the resources for each one.
Andrew Neil
As stated in this similar thread, the key is: don't try to do everything at once!
You've got the sensor part working, so set that aside for now.
Now concentrate on just the Bluetooth part - without the sensor.
Find documentation & support for the BlueNRG-M2SA here:
https://www.st.com/en/wireless-connectivity/bluenrg-m2.html
Get familiar with the ST-provided examples.
Kumar123Author
Hi
I have checked both the BlueNRG-M2SA and ISM330DHCX, and they are working fine. Now, how can I integrate the two and send data via a BLE app? Please let me know.
Andrew Neil
The same way that you'd integrate any two functions.
What have you tried?
Where are you stuck?
