NUCLEO 144 H7 LEGACY for programming an external MCU
Dear ST team,
I am planning to use STM32H753ZIT6 in my design and also planning to use NUCLEO 144 H7 LEGACY for development activities. Could anyone help me whether I can use the NUCLEO 144 H7 LEGACY board to program the STM MCU which is going to assemble in my board? If possible please let me know how to isolate the on board MCU which is present in the NUCLEO 144 H7 LEGACY board.
Shyam
mƎALLEm
mƎALLEmBest answer
My stand point:
To my knowledge, the NUCLEO 144 boards having STLINK V2 have been deprecated from awhile for H7 MCUs. The boards now feature STLINK V3. So if you purchase the board from a distributor (unless they do have V2 in an old stock).
If you need a STLINK V2  on a NUCLEO 144 board (that you can use it externally) you can purchase NCULEO-F439 (Not H7 product:(
https://www.st.com/en/evaluation-tools/nucleo-f439zi.html
mƎALLEm
Hello, @shyammurali and welcome to the St community,
If yes that's not possible (there is no modification available) to use that ST-LINK to program an external MCU target.
Andrew Neil
Does your board have the break-off ST-Link V2.1 part - like this:
If it does, then this applies:
https://www.st.com/resource/en/user_manual/um1974-stm32-nucleo144-boards-mb1137-stmicroelectronics.pdf#page=20
via: https://www.st.com/en/evaluation-tools/nucleo-h743zi.html#documentation
However, this has  a number of limitation; a standalone ST-Link is not expensive - I would strongly suggest that you get one!
https://www.st.com/en/development-tools/hardware-debugger-and-programmer-tools-for-stm32.html
Be sure not to get a fake/clone!
mƎALLEm
Indeed otherwise (my previous post), not possible.
Hi @Andrew Neil , @mƎALLEm ,
Thank you for the support earlier.
My MCU is designed for working at 3.3V, Is this voltage compatible with the ST Link programmer?
I want to know whether I need to put any level translator in between for SWDIO, SWCLK, SWO, VCP_RX, VCP_TX, NRST signals and the programming connector if 3.3V is not compatible.
Shyam
New thread for this new question: STM32H753ZIT6 - ST LINK Programmer working voltage compatibility
