Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
  • March 12, 2024
  • 3 replies
  • 1613 views
While trying to disable TZEN on a NUCLEO-WBA52CG boar after running the GPIO_IOToggle_TrustZone Example an both LEDs working as expected i encountered the error Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
after switching from RP Level 1 to RP Level 0 and deactivating the TZEN Option bit
Best answer by STTwo-32
Hello @Isko
I suggest you take a look at this post. It should be helpful.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @Isko
Best Regards.
STTwo-32
IskoAuthor
Hello @STTwo-32
can you explain to me how the process works and what exactly i nee to do
regards
Isko
STTwo-32
I suggest you take a look at the part 3.7 of the DS14127 and the RM0493. They should be helpful.
Best regards.
STTwo-32
