Could help me identify this HDD (Hard Drive PCB) TVS diode part? SUG SUA
  • August 24, 2024
  • 6335 views
Hi ,
Could help me to identify the model of this TVs diode
it’s from WD external 4TB HDD
Thanks in advance.
Tesla DeLorean
Guru
August 24, 2024
"the marking is SUA, which corresponds to the SMA6F5.0A-TR, which can be found today with 6AI marking."
https://community.st.com/t5/other-hardware/hi-could-you-please-help-me-identify-this-diode/td-p/197883
AyoobAuthor
Thanks for reply ,
What about the first TVs Diode which stands with SUG marking ?
Tesla DeLorean
Guru
August 24, 2024
BarryWhit
Lead
August 24, 2024
@Lina_DABASINSKAITE , here's another example of missing labels. The forum sees a slow but steady stream of such chip identification help requests, but there's no forum label for it. In lieu of a dedicated subforum, a dedicated label would be nice.
"- If someone's post helped resolve your issue, please thank them by clicking ""Accept as Solution"".- Please post an update with details once you've solved your issue. Your experience may help others."
Peter BENSCH
@BarryWhit There is a label: Power Managment > Discretes
Well, maybe not the ideal combination, but should mostly work - doesn’t it?
/Peter
Tesla DeLorean
Guru
August 25, 2024
As it is it shows up in my feed, I'm Ok with it, and the more times we answer the better the chance of a direct Google Hit for the self-service customers
These particular diodes being a pain due to lack of marking documentation, and the markings changing from current issue parts.
ST STMICRO DIODE SUA SUG MARK MARKING
HARD DRIVE DIODES
600W TVS
OLD: SUA SMA6F5.0A NEW: 6AI
OLD: SUG SMA6F13A NEW: 6AY
