piyushsurani
sparkfun xm125 radar module with stm32
  • March 31, 2025
  • 1 reply
  • 769 views
Any one have example code to connect sparkfun xm112 radar module with stm32f407 or other stm32.
1 reply
Andrew Neil
Welcome to the forum.
To get started, please see: How to write your question to maximize your chances to find a solution.
@piyushsurani wrote:
 sparkfun xm112 radar module .
you mean this: https://www.sparkfun.com/sparkfun-pulsed-coherent-radar-sensor-acconeer-xm125-qwiic.html ?
Always helpful to give a link - so people can be sure what you're referring to
Don't Sparkfun have any?
Or the actual device manufacturer - Acconeer ?
https://www.acconeer.com/products/
https://developer.acconeer.com/
Did you try the "visualization tool" mentioned on the sparkfun page?
The thing to remember is that the module neither knows nor cares what microcontroller you use - its behaviour is not different for an STM32 from any other controller.
The only thing that'll be specific to the STM32 is the low-level control of the I2C, UART, or whatever - for that, ST provide plenty of examples.
Above that, the module will just work as specified in its datasheet.
PS:
It seems that Acconeer are an ST Partner - so should be able to help:
https://www.st.com/en/partner-products-and-services/xe125.html
GitHub is also a good place to search for code; eg,
https://github.com/search?q=XM125&type=repositories
