Product development with MCUs
  • April 7, 2026
  • 5 replies
  • 298 views
I want to become a person who can develop MCU based products. How can I improve on my skill. How can i Achieve my goal? Eg. Currently I have been given AVAS system development task.
The best way to become better at something is to do that thing. If you already have a task to do, do that and you will become better over time.
Andrew Neil
@sanket471  Also, spend time studying that thing.
As @unsigned_char_array suggests, leaping straight into a major development with no experience or foundations is probably not a great approach.
Start simple with basics, and work up.
See here.
And a practical approach here.
Microcontroller development is at the intersection of two things:
  1. Electronics
  2. Software.
So you'll need to study & practise both.
unsigned_char_array
Lead III
April 7, 2026
As in Acoustic vehicle alerting system? That's a serious project to first start with! Automotive products have strict requirements.
Good. Writing embedded code that interacts with hardware is fun and challenging.
I don't know what your current skill level is. I don't know what your weaknesses are. You can learn by doing hobby projects and looking at examples. You can also take courses. Best is a combination of both.
I have a formal education where I learned to program MCUs and DSPs in assembly, C and C++. I learned about CPU architectures and about digital logic. In addition to electronic circuit design. While I learned more by doing my formal education provided a solid base.
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
Andrew Neil
Looks like it:
https://community.st.com/t5/automotive-mcus/pinout-details-for-all-variants-of-sr5e1e7-mcu/td-p/890685
Indeed!
Andrew Neil
Who gave you that task ?
Discuss with them your training & mentoring ...
