Unable to flash STM32F756 with st-flash
Moved from MPUs forum.
I have made a custom PCB with a STM32F756 and I'm trying to program this MPU through STlink. My main workstation runs Linux and I use stlink tools.
To flash this MPU, I have connected ST-Linkv2 to my PCB (NRST, SWCLK, SWDIO, SWO, GND) and I can obtain a answer from MPU:
hilbert:[~/zephyros/zephyr/samples/basic/blinky/src] > st-info --probe
Found 1 stlink programmers
 version: V2J29S7
 serial: 49FF69065050825521491967
 flash: 1048576 (pagesize: 2048)
 sram: 327680
 chipid: 0x449
 dev-type: STM32F74x_F75x
 But I unable to flash a test program... I have tested with standard user or root.
hilbert:[/usr/local/bin] > ./st-flash --debug --connect-under-reset write ~/cvs/firmware-europulse/build/zephyr/zephyr.bin 0x08000000
st-flash 1.8.0-121-g8c34a4e
2026-05-22T15:44:31 DEBUG common.c: *** looking up stlink version ***
2026-05-22T15:44:31 DEBUG common.c: st vid = 0x0483 (expect 0x0483)
2026-05-22T15:44:31 DEBUG common.c: stlink pid = 0x3748
2026-05-22T15:44:31 DEBUG common.c: stlink version = 0x2
2026-05-22T15:44:31 DEBUG common.c: jtag version = 0x1d
2026-05-22T15:44:31 DEBUG common.c: swim version = 0x7
2026-05-22T15:44:31 DEBUG common.c: stlink current mode: mass
2026-05-22T15:44:31 DEBUG usb.c: JTAG/SWD freq set to 0
2026-05-22T15:44:31 DEBUG common.c: *** stlink_enter_swd_mode ***
2026-05-22T15:44:31 DEBUG usb.c: ENTER_SWD error (0x09)
2026-05-22T15:44:31 DEBUG common.c: *** stlink_jtag_reset 0 ***
2026-05-22T15:44:31 ERROR usb.c: WRITEDEBUGREG read reply failed: LIBUSB_ERROR_PIPE
2026-05-22T15:44:31 DEBUG common.c: *** stlink_jtag_reset 1 ***
2026-05-22T15:44:34 ERROR usb.c: DRIVE_NRST read reply failed: LIBUSB_ERROR_TIMEOUT
2026-05-22T15:44:34 ERROR usb.c: WRITEDEBUGREG read reply failed: LIBUSB_ERROR_PIPE
2026-05-22T15:44:34 ERROR usb.c: READDEBUGREG read reply failed: LIBUSB_ERROR_PIPE
2026-05-22T15:44:34 WARN common.c: NRST is not connected
2026-05-22T15:44:36 DEBUG common.c: *** stlink_soft_reset (halt) ***
2026-05-22T15:44:36 DEBUG read_write.c: *** stlink_write_debug32 0xa05f0003 to 0xe000edf0
2026-05-22T15:44:36 ERROR usb.c: WRITEDEBUGREG read reply failed: LIBUSB_ERROR_PIPE
2026-05-22T15:44:36 DEBUG read_write.c: *** stlink_write_debug32 0x01000501 to 0xe000edfc
2026-05-22T15:44:36 DEBUG read_write.c: *** stlink_write_debug32 0x00000008 to 0xe000ed30
2026-05-22T15:44:36 ERROR usb.c: READDEBUGREG read reply failed: LIBUSB_ERROR_PIPE
2026-05-22T15:44:36 DEBUG read_write.c: *** stlink_write_debug32 0x05fa0004 to 0xe000ed0c
2026-05-22T15:44:36 ERROR common.c: Soft reset failed: error write to AIRCR
2026-05-22T15:44:39 ERROR usb.c: GET_CURRENT_MODE read reply failed: LIBUSB_ERROR_TIMEOUT
2026-05-22T15:44:39 DEBUG common.c: stlink mode: unknown!
2026-05-22T15:44:39 DEBUG common.c: *** stlink_enter_swd_mode ***
2026-05-22T15:44:39 DEBUG common.c: Loading device parameters....
2026-05-22T15:44:39 DEBUG common.c: *** stlink_core_id ***
2026-05-22T15:44:39 DEBUG common.c: core_id = 0x5ba02477
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0x410fc271 at 0xe000ed00
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0x10016449 at 0xe0042000
2026-05-22T15:44:39 DEBUG chipid.c: detected chip_id parameters
2026-05-22T15:44:39 DEBUG chipid.c: # Device Type: STM32F74x_F75x
2026-05-22T15:44:39 DEBUG chipid.c: # Reference Manual: RM0385
2026-05-22T15:44:39 DEBUG chipid.c: chip_id 0x449
2026-05-22T15:44:39 DEBUG chipid.c: flash_type 5
2026-05-22T15:44:39 DEBUG chipid.c: flash_size_reg 0x1ff0f442
2026-05-22T15:44:39 DEBUG chipid.c: flash_pagesize 0x800
2026-05-22T15:44:39 DEBUG chipid.c: sram_size 0x50000
2026-05-22T15:44:39 DEBUG chipid.c: bootrom_base 0x100000
2026-05-22T15:44:39 DEBUG chipid.c: bootrom_size 0xedc0
2026-05-22T15:44:39 DEBUG chipid.c: option_base 0x1fff0000
2026-05-22T15:44:39 DEBUG chipid.c: option_size 0x20
2026-05-22T15:44:39 DEBUG chipid.c: flags 2
2026-05-22T15:44:39 DEBUG chipid.c: otp_base 0
2026-05-22T15:44:39 DEBUG chipid.c: otp_size 0
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0x0400c000 at 0x1ff0f440
2026-05-22T15:44:39 INFO common.c: STM32F74x_F75x: 320 KiB SRAM, 1024 KiB flash in at least 2 KiB pages.
2026-05-22T15:44:39 DEBUG common.c: *** stlink_force_debug_mode ***
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0x00001800 at 0xe0042008
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_write_debug32 0x00001800 to 0xe0042008
2026-05-22T15:44:39 DEBUG common.c: *** stlink_status ***
2026-05-22T15:44:39 DEBUG usb.c: core status: 02030003
2026-05-22T15:44:39 DEBUG common.c: core status: halted
file /home/bertrand/cvs/firmware-europulse/build/zephyr/zephyr.bin md5 checksum: 96798a8dcdb294a3e6a16698c07e9c67, stlink checksum: 0x00196c0b
2026-05-22T15:44:39 INFO common_flash.c: Attempting to write 18120 (0x46c8) bytes to stm32 address: 134217728 (0x8000000)
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0000000000 at 0x40023c0c
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_write_debug32 0x000000f2 to 0x40023c0c
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0x80000000 at 0x40023c10
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_write_debug32 0x45670123 to 0x40023c04
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_write_debug32 0xcdef89ab to 0x40023c04
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0000000000 at 0x40023c10
2026-05-22T15:44:39 DEBUG common_flash.c: Successfully unlocked flash
EraseFlash - Sector:0x0 Size:0x8000 2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0000000000 at 0x40023c10
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_write_debug32 0x00000002 to 0x40023c10
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0x00000002 at 0x40023c10
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_write_debug32 0x00010002 to 0x40023c10
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0x00010000 at 0x40023c0c
2026-05-22T15:44:39 DEBUG usb.c: READDEBUGREG error (0x18)
2026-05-22T15:44:39 DEBUG read_write.c: *** stlink_read_debug32 0x00070000 at 0x40023c0c
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_read_debug32 0x00000002 at 0x40023c10
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_write_debug32 0x80000002 to 0x40023c10
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_read_debug32 0000000000 at 0x40023c0c
-> Flash page at 0x8000000 erased (size: 0x8000)
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_read_debug32 0x00100000 at 0x40023830
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_write_debug32 0x00100000 to 0x40023830
2026-05-22T15:44:40 DEBUG usb.c: READDEBUGREG error (0x18)
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_write_debug32 0x000000f2 to 0x40023c0c
2026-05-22T15:44:40 INFO flash_loader.c: Starting Flash write for F2/F4/F7/L4
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_write_debug32 0xa05f0003 to 0xe000edf0
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_write_debug32 0xa05f000b to 0xe000edf0
2026-05-22T15:44:40 DEBUG common.c: *** reading target voltage
2026-05-22T15:44:40 DEBUG usb.c: target voltage factor=000005f0 reading=000002a9
2026-05-22T15:44:40 DEBUG common.c: target voltage = 1075mV
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_write_mem32 52 bytes to 0x20000000
2026-05-22T15:44:40 DEBUG usb.c: GETLASTRWSTATUS2 access port fault
2026-05-22T15:44:40 WARN flash_loader.c: Failed to write flash loader to sram!
2026-05-22T15:44:40 ERROR flash_loader.c: stlink_flash_loader_init() == -1
2026-05-22T15:44:40 DEBUG usb.c: READDEBUGREG access port fault
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_write_reg
2026-05-22T15:44:40 DEBUG usb.c: WRITEREG access port fault
2026-05-22T15:44:40 DEBUG common.c: *** stlink_run ***
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_read_reg
2026-05-22T15:44:40 DEBUG read_write.c: (16) ***
2026-05-22T15:44:40 DEBUG usb.c: READREG access port fault
2026-05-22T15:44:40 DEBUG usb.c: WRITEDEBUGREG access port fault
stlink_fwrite_flash() == -1
2026-05-22T15:44:40 DEBUG common.c: *** stlink_exit_debug_mode ***
2026-05-22T15:44:40 DEBUG read_write.c: *** stlink_write_debug32 0xa05f0000 to 0xe000edf0
2026-05-22T15:44:40 DEBUG common.c: *** stlink_close ***
First question : why st-flash does complain about unconnected NRST signal ? I have connected NRST to pin 15 of SWD connector.
Second question : if I understand, I can read and write commands, but I cannot flash progam. What is my mistake ?
Best regards,
JB
Andrew Neil
welcome to the forum
Please see How to write your question to maximize your chances to find a solution for best results.
Then you need to post your schematic.
Has this PCB ever worked before?
The STM32F7 is an MCU - not an MPU.
You need to be using the MCU tools; eg, STM32CubeProgrammer.
What ST-Link are you using?
How to recognize a genuine ST-LINK/V2 versus a cloned one
JKBAuthor
PCB runs as expexcted. I have checked all signals and all power supplies.
On schematic, stlink is connected to PROG{PROG} (NRST is connected to WKUP). Only TVS diodes are added on PROG bus.
My StLInkv2 is an official one, not a copy.
Regards,
JB
mƎALLEm
I don't know about Zephyr environment but you need to check if you are able to connect with your custom board using
STM32CubeProgrammer tool.
JKBAuthor
I have exactly the same error.
I receive some errors during connection but after hard reset of PCB, connection is done but why is voltage only 1.57V ? CPU is powered from 3V3 line. And I have exactly the same error "flash loader cannot be loaded".
Regards,
JB
Andrew Neil
There's something wrong with your power supply:
