TKana.1
Mar 26, 2024 6:10 AM UTC
STM32CubeProgrammer V2.16 DFU Download Problem
Updated from 2.15 today. Having DFU download problem seen attached.
Board is recognised but upper right still stated as "Not connected" and download fails.
Downgraded to V2.15 and same board connects and downloads OK.
OS: W10 64bit
Board: STM32F767NI custom
Fyi
Timucin KANATLI
STTwo-32
STTwo-32Best answer
Jul 4, 2024 1:57 PM UTC
Hello @TKana.1
Issue has been solved on the Last version of the STM32CubeProgrammer (V2.17.0).
Best Regards.
STTwo-32
STTwo-32
Mar 26, 2024 7:24 AM UTC
Hello @TKana.1
Are you having the same problem as mentioned on the following post:
STM32CubeProgrammer 2.16.0 fails to program STM32L... - STMicroelectronics Community
Best Regards.
STTwo-32
TKana.1
TKana.1Author
Mar 26, 2024 8:06 AM UTC
Exactly. Mine works on V2.15
Best Regards,
Tim
STTwo-32
Mar 27, 2024 8:20 AM UTC
I've added your problem to the ticket created for the post mentioned on my first Comment. We will be back to you as soon as there is any News.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @TKana.1
Best Regards.
STTwo-32
Dec 7, 2024 5:25 AM UTC
No, I got the same problem. And I have test V2.17.0 and V2.18.0, but they don't work. I can still use V2.15.0.
STTwo-32
Dec 7, 2024 5:55 PM UTC
Hello @6689157
Could you please create a new post with the issue you have and a full description of the problem (MCU or board used, versions, OS on your PC,...).
Best Regards.
STTwo-32
