CubeProgrammer + ST-LINK V2 doesn't work anymore
I have created a firmware for a STM32L010F4Px microcontroller.
I was able to Connect and Download Firmware by using ST-LINK V2.
For some reason, I can't connect to the MCU at the moment by using CubeProgrammer + ST-LINK V2.
Instead, I can connect/debug my microcontroller by using a SEGGER J-Link Ultra+ + J-Flash tool.
The log from CubeProgrammer doesn't give me much details:
13:28:34 : UR connection mode is defined with the HWrst reset mode
13:28:34 : ST-LINK SN : 37FF71064E573436D2C11443
13:28:34 : ST-LINK FW : V2J47S7
13:28:34 : Board : --
13:28:34 : Voltage : 3.28V
13:28:34 : Error: Unable to get core ID
13:28:34 : Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication
paraschivescueBest answer
I have solved the mystery.
The problem was a wire that was no longer making good contact between ST-LINK v2 debugger and my development board on which the microcontroller is soldered.
Thank you all for your involvement and help!
Have a good day!
AScha.3
Try in CubeProgrammer with reset : software   setting.
I have tried all options including Software Reset but without any success:
13:26:09 : STM32CubeProgrammer API v2.22.0 | Windows-64Bits
13:26:35 : UR connection mode is defined with the SWrst reset mode
13:26:35 : ST-LINK SN : 37FF71064E573436D2C11443
13:26:35 : ST-LINK FW : V2J47S7
13:26:35 : Board : --
13:26:35 : Voltage : 3.28V
13:26:35 : Error: Unable to get core ID
13:26:35 : Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication
mƎALLEm
@paraschivescue ,
Any low power used in the application you've already uploaded?
Look at this post. Use "Power down" mode.
Andrew Neil
So what changed?
  • Something in your firmware ?
  • Something in your hardware setup ?
  • Tool update(s) ?
  • Other ?
Is that using the exact same cable & connections ?
Is it a genuine ST-Link ?
How to recognize a genuine ST-LINK/V2 versus a cloned one
Can it connect to any other target(s) ?
paraschivescueAuthorBest answer
Have a good day!
