gil_dobjanschi
Senior
April 27, 2026
Starting a new project with an existing ioc2 file
I would like to learn if there is an easy way in STM32CubeMX2 to start a new project with an existing ioc2 file. It seems that the only way I can do this is make a copy of the ioc2 file, do a text find and replace for the name of the project and reopen the project in MX2.
In essence, I like to start a project from a working ioc2 configuration and modify it to work on a fork of the project. I don't want to recreate a complex configuration from scratch because I found the hard way that it is easy to make mistakes or to omit something.
Thank you,
-Gil
Please check the follow-up discussion here: Issue with Save As feature in STM32CubeMX2
STackPointer64Best answer
You can open the working ioc2 configuration and click Project > Save As. You will then be prompted to enter a new project name and a new directory.
Best regards,
To improve visibility of answered topics, please click 'Accept as Solution' on the reply that resolved your issue or answered your question.
Best regards,
gil_dobjanschi
Senior
April 27, 2026
Thank you @STackPointer64!
