paolog
May 4, 2026 07:57 UTC
Error installing STMicroelectronics.button_part_drivers.2.0.0 pack
Thank you @B.Montanari  for the complete guide. Unfortunately on my computer the project is not created as packs can't be downloaded, error is the following (in this case for button pack):
Could not save pack of pack-URL: https://developer.st.com/st-pack-server/api/v1/pack/STMicroelectronics.button_part_drivers.2.0.0.pack, got: Unsupported `GLOBAL_AGENT.HTTP_PROXY` configuration value: URL protocol must be "http:".
I'm behind a proxy (set at system level), and if I use the URL listed I'm able to download and manually install the pack. I tried setting proxy information on MX2 as IP:port with no result.
Is there a way to solve this?
BR
Edit: moved from How to create a new project with STM32CubeMX2
paolog
paologBest answer
May 5, 2026 07:57 UTC
Found the reason of my issue. I had Windows system variables HTTP_PROXY and HTTPS_PROXY set without "http://" in front of IP. Once corrected everything worked.
Oussama_TROUDI
May 4, 2026 14:30 UTC
Hi @paolog
In this case, what you need is to configure a proxy or a certificate to be able to access the servers and download packages.
  • Get your certificate from your company IT or company portal.
  • Place it under C:\certificate, for example.
  • Add the Windows environment variable NODE_EXTRA_CA_CERTS with the path to this certificate file. (Make sure that the path has no quotes.)
  • Finally, restart STM32CubeMX2.
You can also refer to this article for more details on: How to configure the proxy or certificate
paolog
paologAuthor
May 5, 2026 07:53 UTC
Hi @Oussama_TROUDI , thank you for your reply.
I followed the directions on the above link as much as possible, as we don't use Visual Studio Code. We installed the certificate, defined the variable NODE_EXTRA_CA_CERTS to point to the certificate file, and defined proxy in MX2 as "http://Proxy-address:port". But the error is still there.
Should system variable GLOBAL_AGENT_HTTP_PROXY be defined?
Any other option to solve this?
Thank you.
paolog
paologAuthorBest answer
Oussama_TROUDI
May 5, 2026 08:14 UTC
Hi @paolog
I'm glad you found the root cause and that everything is working now!!
