Support for STM32U0 series in STMCubeMX
I'm unable to use the STM32Cube FW_U0 V1.1.0.
I have downloaded the package in Cube MX - Version 6.11.1 however when trying to create a project using the
"Start My project from Example - ACCESS TO EXAMPLE PROJECT SELECTOR" i get the following dialogue:
Sean
STTwo-32
STTwo-32Best answer
Hello @Jorgie
The issue has been fixed. Please try again on your side (don't forget to login to Your CubeMX so it can update his files).
Best Regards.
STTwo-32
STTwo-32
Hello @Jorgie
I suggest you to take a at this
Article. It should solve your issue.
Best Regards.
STTwo-32
JorgieAuthor
Thank you,  I'll give that a go tomorrow.
I do have to say that this step should not be required as most packages install without problems.
