ATkac.3
Sep 28, 2024 6:28 AM UTC
STM32CubeMX generate incorrect linker file
Hi!
STM32CubeMX generated an incorrect linker file, and I can't build the project with cmake.
Example project attached to the post.
cmake version - 3.28.1
STM32CubeMX version 6.12.1
STTwo-32
STTwo-32Best answer
Dec 2, 2024 8:25 AM UTC
Hello @ATkac.3
This behavior has been solved on the last version of the STM32CubeMX V6.13.0. Thank you so much for reporting.
Best Regards.
STTwo-32
Sep 28, 2024 2:32 PM UTC
What is incorrect about it? Why can't you build the project? Show more information, error messages, screenshots, etc.
Pavel A.
Sep 28, 2024 7:38 PM UTC
Yes this is a known issue, already in handling.
Sep 30, 2024 8:47 AM UTC
Hello @ATkac.3 ,
First let me thank you for posting.
I suggest that you take a look at this Post.
This issue was sent to the concerned team (under internal ticket number 191745).
Best Regards.
Mahmoud
STTwo-32
STTwo-32Best answer
Hello @ATkac.3
Best Regards.
STTwo-32
