Searching for STM32s with Advanced Motor Control Timers
I'm searching for a MCU with one or two advanced motor control timers to control 1 or 2 bldc motors.
For this purpose I use the MCU selection tool from here: STM32 family of 32-bit microcontrollers (MCUs) - STMicroelectronics
When I use the filter for one or two advanced motor control timers the MCUs from the STM32G series are never displayed and I don't understand why? How should I search for all MCUs with motor control functionalities?
Thanks for every hint!
Best regards,
Roger
rogdivBest answer
Hi Andrew,
Thanks for this tip, I have also found this page STM32 Ecosystem for Motor Control - STMicroelectronics. Which is very useful because it shows an overview over the different MCUs for motor control applications.
Andrew Neil
rogdivAuthorBest answer
Hi Andrew,
Andrew Neil
you're welcome.
if your problem is solved, please mark the solution.
