New CubeMX-created project does not build in CubeIDE v2.1.0
Split from STM32CubeIDE version 2.1.0 won't generate IOC project file as this is a new question.
Please keep to one question per thread.
Thanks both Ghofrane GSOURI & Andrew Neil for pointers. Adopting the method shown in the presentation. I have selected a nucleo development board to create an STM32MX project. I have then created a STM32CubeIDE projecfrom the MX project. Having not written any code yet, I'm getting compilation errors but have no idea why? The errors are relating to files marked with a red x below:
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello @GChol.1
I have just run a test using your IOC file, and the project builds successfully, as shown in the screenshot below.
Please try the following on your side:
1- Move your IOC file to a new, empty folder.
2- Open this IOC file in STM32CubeMX.
3- Generate the code for your IDE from STM32CubeMX.
5- Open the generated project in the IDE and rebuild it.
THX
Ghofrane
Andrew Neil
You're welcome.
Please mark the solution in that other thread.
Which version of CubeMX did you use?
Geoff104Author
CubeMX V6.17.0. I have also tried with CubeIDE V2.0.0 and V2.1.0
Ghofrane GSOURI
Hello @Geoff104
Could you please provide your IOC?
I will be waiting for your feedback.
THX
Ghofrane
GChol.1
Hi @Ghofrane GSOURI , Geoff104 here (Had to use work account as I seem to be locked out of my personal account) Please see attached *.ioc file
Ghofrane GSOURI
Hello @GChol.1
THX
Ghofrane
GChol.1
@Ghofrane GSOURI Many thanks, suggestions worked!
Ghofrane GSOURI
Hello @GChol.1
Please mark the post that helped you as the best answer.
THX
Ghofrane
