Eclipse executable launcher is unable to locate its companion shared library
- 2 replies
- 4112 views
System versions macos 15.1.1 stm32cubemx 6.13, stm32cubeide1.17. When I generate code using cubemx and select stm32cubeide in the toolchain, an Eclipse prompt box will pop up, indicating that The Eclipse executable launcher was unable to locate its companion shared library, I have replaced several recent versions of stm32cubemx, but the problem still exists. Have you encountered similar situations? Can you provide a solution? I'm almost going crazy with my Mac
