Khouloud OTHMANBest answer
Jun 1, 2021 1:50 PM UTC
Hello @Vyacheslav ,
In fact, some project settings options become read-only once the project is saved. To modify these options, the project must be saved as a new project using the File> Save Project as menu:
The Application Structure is one of those options, thus it should be set before the first code generation.
Otherwise, you can re-save the project using Save Project as…
Hope this answers your question. If this this case, please click on the Select as Best button on my reply . This will help other members of the community find this solution more quickly :)
Khouloud.
