Senior
Where the software packages stored and how to change their default location?
I'm a newer for the CubeIDE. In the standalong CubeMX, I can change the default packages location to another location. But I can't find such an entry in CubeIDE.
Thanks.
    TDKBest answer
    Window -> Preferences -> STM32Cube -> Firmware Updater -> Repository Setup
    Solved: How to change the Repository directory (location)? - STMicroelectronics Community
    TDKBest answer
    divergerAuthor
    Senior
    Thanks for the suggestion. I think the MX and the IED can share the same repository. right?
    Yes. By default, the do share the same repository.
