M_Deloizy
Unable to access Calibration Words with STM32H503RBT
I try to read VREFINT_CAL word :
uint16_t *VREFINT_CAL=(uint16_t *)(0x08FFF810);
uint16_t v = *VREFINT_CAL;
When running, Hard fault interrupt is called.
Memory protect seems not active (MPU not used, GTZC not enabled).
What can be the problem ?
Thanks.
    mƎALLEm
    mƎALLEmBest answer
    This behavior is observed when the ICACHE is enabled and when RO and OTP regions are accessed. So you need to use the MPU.
    Please refer to this article: https://community.st.com/t5/stm32-mcus/how-to-avoid-a-hardfault-when-icache-is-enabled-on-the-stm32h5/ta-p/630085
    mƎALLEm
    mƎALLEmBest answer
    M_Deloizy
    M_DeloizyAuthor
    Thanks very much. It's now Ok !
