STM32CubeIDE installation issues
Can multiple versions of a software be installed on one computer or system? The latest version I recently downloaded doesn't include MX. Should I install version 1.19.0, or use the uninstallation method for version 2.0.0?
Peter BENSCH
Peter BENSCHBest answer
What @Ozone means can be found in the early heads-up and in the announcment, for example.
Peter BENSCH
Yes, you can install multiple versions of the STM32CubeIDE side by side – in separate directories, of course. On Windows machines, keep the path to them as short as possible, e.g. C:\ST\CIDE2200\.
/Peter
Ozone
Principal
If it's about that, MX is available as a separate package, it is not integrated in Cube anymore.
There is a thread here about this topic (which I can't find at the moment).
Peter BENSCH
