"Range [0,-1) out of bounds for length 48" trying to open Debug Configuration
  • July 29, 2025
  • 13 replies
  • 2148 views
Hello, I'm trying to set the debug configuration of my project, but I cannot open the debug file under C/C++ Application. Besides, running this project was not successful either.
I have tried switching workspace and uninstalling IDE, but neither worked.
Can anyone help me solve my problem? Thank you very much.
Best answer by Imen.D
Hello @Levy-hy ,
We have reproduced this issue with CubeIDE 1.19 and I escalated it to our CubeIDE team for analysis (internal ticket number: 215198).
PS: Ticket number: 215198 is an internal tracking number and is not accessible or usable by customers.
mbarg.1
Senior III
July 29, 2025
Version of STM32CubeIde?
Version 1.18 are buggy - update to 1.19
Levy-hyAuthor
Mine is 1.19, already the latest one
Andrew Neil
Did you try pressing the 'Details' button?
The message says, "Out of bounds for length 48".
The name of your Debug Configuration is very long* - maybe it's too long?
Maybe try just shortening the name?
PS
* The name certainly is over 48 characters!
Levy-hyAuthor
Details are the same. I tired to rename the project to make its name shorter, but it didn't work either.
Then I opened another project, and found its run configuration back to normal. So I assume the problem lies in the project. But the project is the example AI demo project of STM32N6 and I'm stuck here:(
@Levy-hy , Did you make any changes to the Demo project?
Check Project configuration, such as memory allocation and linker scripts are correctly configured.
You can also, perform a clean build of the project to ensure no corrupted files are causing this issue.
Hello @mbarg.1
Try follow the steps in this article : How to debug STM32N6 using STM32CubeIDE
Imen.DBest answer
Hello @Levy-hy ,
Hello Imen.D,
I am also facing the same issue . Is there a resolution to the issue available?
Ghofrane GSOURI
Hello @Levy-hy
As a workaround, try removing the following line from your .project file:
<nature>com.st.stm32cube.ide.mcu.MCUAppSProjectNature</nature>
You will be able to debug your project successfully.
THX
Ghofrane
