Jun 26, 2024 5:14 PM UTC
Out of memory error.lwip
Good evening everyone; I was going to ask about something the size of it. If anyone has any information, I'd be happy. STMCube ide is also the LWip library tool. For MQTT connection via Ethernet. After publishing and subscribing for a certain period of time (30-40 minutes), "Out of memory error." (-1) error occurs and publishing and subscribing operations stop. How can I do that.
    Andrew Neil
    Andrew NeilBest answer
    Jun 26, 2024 5:19 PM UTC
    You're going to need to give a lot more detail!
    https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
    Where, exactly, does it occur?
    Sounds like you have a memory leak - ie, you keep allocating memory, but never release it.
    You need to review your code (maybe also the LwIP documentation, and documentation for your MQTT library) to see where memory is being allocated, and check that it always gets released (de-allocated).
    Andrew Neil
    Nov 20, 2024 8:01 PM UTC
    Hello, the problem in question still persists, most likely there is a memory leak as you said. So how do I free the allocated areas in memory? By clearing the buffers with memset? Can you examine the function blocks I publish and subscribe to?
    Andrew Neil
    Nov 21, 2024 9:04 AM UTC
    the problem in question still persists?
    So why have you marked it as solved?
    You can un-mark the solution:
    https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256#:~:text=If%20you%20accidentally%20chose%20the%20wrong%20post%20as%20solution%2C%20you%20can%20always%20revert%20this%20action%20by%20clicking%20%22Not%20the%20Solution%22
    First, you need to confirm that for sure
    You need to identify where, exactly, that memory is being allocated, and why it is not getting freed.
