Newbie, question about opening cube
Edit by ST Moderator: This post has been translated from Chinese to comply with the ST Community Terms and Conditions (§10.2).
Why is it that after turning off the computer after downloading and using it, and turning it on again, the cube won't open again?
为什么每一次下载使用完毕关闭电脑后,再次开启电脑,cube就没法再次打开了?
Semer CHERNI
Hello @Dark_blue
First le me thank you for posting.
Could you provide more details about the scenario which leads to this behavior?
kind regards,
Semer.
Andrew Neil
As @Semer CHERNI said, you need to supply more details - see: How to write your question to maximize your chances to find a solution
Did you shut everything down cleanly?
STM32CubeIDE should certainly work after a computer has been properly shut down & restarted.
What, exactly, do you mean by that?
How do you try to open it.
Do you get error messages? Anything
