how to get compile_commands.json from CubeIDE
A lot of new helpful tools can do something with the code (for example check dependencies etc) based on "compile_commands.json" - is there an option to generate this file in CubeIDE?
    STTwo-32
    Hello @dambo
    I suggest you to take a look at this post. It should be helpful for your request.
    Best Regards.
    STTwo-32
