How to debug NUCLEO-H563ZI using STM cube IDE
Hello everyone I am new to the STM boards I had received my board today I had tried the basic LED toggle code and it is working fine but can someone please guide me to see the debug message on the code like I can see the printf statements how can I see those debug messages can someone please help me.
Andrew Neil
Andrew NeilBest answer
Yes, you can use Segger's RTT on STM32.
See the Segger documentation for details:
https://www.segger.com/products/debug-probes/j-link/technology/about-real-time-transfer/
It's proprietary to Segger so, if you have questions about Segger's RTT, you need to ask Segger:
https://www.segger.com/support/technical-support/
https://forum.segger.com/
PS:
Note that RTT relies on J-Link - it won't work with ST-Link (or other debug probes)
Andrew Neil
Welcome to the forum.
Please see  How to write your question to maximize your chances to find a solution for best results.
@Mathan-Mukesh wrote:
Hello everyone I am new to the STM boards .
Do you have experience with any other microcontrollers? With programming in general?
Was that using an example from CubeIDE?
 to see the debug message on the code .
What debug messages?
You mean you have put printf statements into your code?
printf is a standard C function which sends output to stdout.
On a "normal" platform like a PC, output to stdout will appear on the user's console - but an embedded system like a Nucleo board doesn't have such a thing.
So you have to decide where your stdout output will appear: you do that by writing suitable code - commonly to a UART.
Before getting involved in the complexities of printf and stdout, I would strongly suggest that you get basic UART output working using HAL_UART_Transmit:
https://community.st.com/t5/stm32-mcus/implementing-uart-receive-and-transmit-functions-on-an-stm32/ta-p/694926
At the end of that article, it will direct you to the next step - using that to get printf working to a UART.
Hi @Mathan-Mukesh and welcome to the Community,
With the KB articles mentioned by @Andrew Neil , you can also refer to this AN4989 Application note STM32 microcontroller debug toolbox.
