How can i get printF to work in other .c files?
I just started out a project with FreeRtos and followed this and managed to get it to work.
How to redirect the printf function to a UART for debug messages
I can also printF from the freertos.c StartXXXTask functions.
But one of the start task functions i call my own method in my custom .C file i can't seem to printF from it. Within that function i can run this and it works, but not printF.
HAL_UART_Transmit(&huart2, buf, strlen((char*)buf), HAL_MAX_DELAY);
Wondering what am I doing wrong?
    iwaggBest answer
    Not sure what I did, but it's working now.
    Andrew Neil
    @iwagg wrote:
     printF
    Why the uppercase 'F' - is this some custom "wrapper" for the standard printf ... ?
    What do you mean by that? It doesn't build? You get no output? Other...?
    iwaggAuthor
    Apologies, that is my typo, it's not a custom wrapper.
    It doesn't work as in no output. It compiles. Tried  putting a HAL uart transmit before and after the printf statement, those work and I get output, just no output from printf.
    Andrew Neil
    Does FreeRTOS have separate streams for each Task? Or require each Task to setup its own printf redirection?
    If so, that would be a FreeRTOS question - not specific to STM32 ...
    https://www.freertos.org/Documentation/RTOS_book.html
    https://www.freertos.org/RTOS-contact-and-support.html
    Likely you haven't got the plumbing setup properly via _write() and __io_putchar()
    Could try
    char buf[64];
    HAL_UART_Transmit(&huart2, (void *)buf, sprintf(buf, "%d\n", 123), HAL_MAX_DELAY);
    iwaggAuthorBest answer
