Facing Hard fault when implementing RTOS on NUCLEO-H563 board
Hi
I am trying to RTOS on my device STM32-H563ZI
I get a hard fault when I hit the function osKernelStart(); in the main loop
When I started debugging ,my code seems to get  hardfault after vStartFirstTask in function xPortStartScheduler()
I am trying to toggle LED in the task  from this example https://www.youtube.com/watch?v=OPrcpbKNSjU
Thank You.
mƎALLEm
mƎALLEmBest answer
I created a project based on NUCLEO-H563 board on which I enabled FreeRTOS and created two tasks each one is toggling a LED. I didn't find any issue. See attachment.
I noticed that you've already opened another thread for the same case with TrustZone enabled.
As you didn't mention in this thread, which TrustZone configuration you set, let's keep this one for TrustZone disabled.
mƎALLEm
mƎALLEmBest answer
